vanthoi
Hairpin NAT not working on RouterOS 6 line WAN load balancing
Mon Jan 07, 2019 5:14 am
I am having problems with my RouterOS. I have 6 WAN lines. I have run load balancing mode. Everything works very stable. It's just that I'm trying to NAT some things that don't work as expected.
The first is about Hairpin NAT.
I tried nat according to the instructions on the wiki. But somehow it doesn't work in internal LAN. This is my NAT configuration:
add action=masquerade chain=srcnat comment="Hairpin NAT" dst-address=172.16.0.10 dst-port=5060 out-interface=LAN protocol=udp src-address=172.16.0.0/22 to-ports=5060
add action=dst-nat chain=dstnat dst-address=ip-of-wan3 dst-port=5060 protocol=udp to-addresses=172.16.0.10 to-ports=5060
add action=masquerade chain=srcnat comment="Hairpin NAT" dst-address=172.16.0.35 dst-port=443 out-interface=LAN protocol=tcp src-address=172.16.0.0/22 to-ports=443
add action=dst-nat chain=dstnat dst-address=ip-of-wan2 dst-port=443 protocol=tcp to-addresses=172.16.0.35 to-ports=443
The second is about NAT out on a fixed WAN IP line. Sometimes it works, sometimes it doesn't work. This is my NAT configuration:
add action=masquerade chain=srcnat comment="Hairpin NAT" dst-address=172.16.0.5 dst-port=4370 out-interface=LAN protocol=tcp src-address=172.16.0.0/22 to-ports=4370
add action=dst-nat chain=dstnat comment="CHAM CONG T1" dst-address=ip-of-wan4 dst-port=4370 protocol=tcp to-addresses=172.16.0.5 to-ports=4370
add action=masquerade chain=srcnat comment="Hairpin NAT" dst-address=172.16.0.6 dst-port=4371 out-interface=LAN protocol=tcp src-address=172.16.0.0/22 to-ports=4371
add action=dst-nat chain=dstnat comment="CHAM CONG T2" dst-address=ip-of-wan4 dst-port=4371 protocol=tcp to-addresses=172.16.0.6 to-ports=4371
add action=masquerade chain=srcnat comment="Hairpin NAT" dst-address=172.16.0.7 dst-port=4372 out-interface=LAN protocol=tcp src-address=172.16.0.0/22 to-ports=4372
add action=dst-nat chain=dstnat comment="CHAM CONG T3" dst-address=ip-of-wan4 dst-port=4372 protocol=tcp to-addresses=172.16.0.7 to-ports=4372
add action=masquerade chain=srcnat comment="Hairpin NAT" dst-address=172.16.0.8 dst-port=4373 out-interface=LAN protocol=tcp src-address=172.16.0.0/22 to-ports=4373
add action=dst-nat chain=dstnat comment="CHAM CONG T4" dst-address=ip-of-wan4 dst-port=4373 protocol=tcp to-addresses=172.16.0.8 to-ports=4373
In this case, "CHAM CONG T1" and "CHAM CONG T4" are already active. But the remaining 2 ip does not work.
vanthoi
Re: Hairpin NAT not working on RouterOS 6 line WAN load balancing
Thu Jan 10, 2019 5:40 am
Can anyone support me this problem.
Thank you!
ivicask
Thu Jan 10, 2019 10:59 am
Thank you!
For me doesnt work without this rule also
add action=masquerade chain=srcnat comment=HAIRPIN dst-address=192.168.1.0/24 out-interface=LAN src-address=192.168.1.0/24
Change ips and out interface to match your network.
Anumrak
Forum Veteran
Forum Veteran
Thu Jan 10, 2019 11:05 am
Hey. If all your rules are identical, maybe your PCs has some firewall rules that blocking your traffic? Like CHAM CONG T2 and CHAM CONG T3.
Anumrak
Forum Veteran
Forum Veteran
Thu Jan 10, 2019 11:07 am
Thank you!
He have this rule already
ivicask
Thu Jan 10, 2019 11:25 am
Thank you!
yes, but he should change it like i have it for test, like 172.16.0.0/24 for both dst and src adress without any ports rule before other dstnat rules
Anumrak
Forum Veteran
Forum Veteran
Thu Jan 10, 2019 11:34 am
Thank you!
I have well working rule in my net, so it is not necessary to dstnat the subnet. And he said all rules are working except 2 hosts. So it should be problem in hosts themselves.
ivicask
Thu Jan 10, 2019 11:42 am
Thank you!
But than it wouldnt even work directly by ip if its firewall problem on them, which i asume it works, and mikrotik redirects to IP so it has nothing to do with DNS or firewall on those computers also.
Right?
Super easy test is to turn off firewall on one pc and see if it works.
vanthoi
Fri Jan 11, 2019 4:24 pm
Sorry guys. I solved the problem. This stupid error because I configured false load balancing. So they had mixed packets together. Causing troublesome errors on. Thank you for your help! By the way, can you ask me? How do I only allow ip or a certain url, only go on a single WAN?
Users browsing this forum: Google [Bot] and 21 guests
