Delid4ve
EoIP vlan issue
Thu Jan 10, 2019 1:52 pm
Hi Guys
So i've got an EoIP tunnel sucessfully configured across an l2tp ipsec site to site VPN. This is for office to home use.
Its configured as follows:
vpn local 192.168.3.1 remote 192.168.3.2
eoip configured for these addresses (loopback)
Office (windows active directory domain)
Bridge (192.168.23.254/24) with all ports added and EoIP tunnel
vlan filtering enabled pvid=3, tagged: EoIP tunnel, untagged: bridge and ports (for now).
Home:
Bridge (192.168.6.1/24) with all ports and EoIP added
vlan filtering enabled pvid=1, untagged: bridge, tagged: port 2
vlan 3 = tagged: bridge, port 2, EoIP tunnel
both vlans go through a switch on port 2.
vlan 1 feed my lan
vlan 3 from the EoIP is tagged to an ubiquiti WAP where i have a wireless network setup on vlan 3.
Static routes:
work: 192.168.6.0/24 - VPN interface
home: 192.168.23.0/24 - VPN interface
Everything works and can communicate except...
I can join the wifi network and i successfully get a lease from the domain controller.
i can access the internet and confirm the external ip is that of the office.
The problem is i cannot access either LAN. ping doesnt get through, i cant access the routers, nothing.
im probably missing something simple here and believe it is down to routes or the domain controller but im stumped after 3 days of trying.
traffic gets through for the wan just not for local.
Any help most appreciated.
Delid4ve
Re: EoIP vlan issue  [SOLVED]
Thu Jan 10, 2019 11:20 pm
So now I feel like a right...
Decided to add a port to the bridge and test it wired..
Full comms.
Turns out it was a dodgy ssid on the ubiquiti, deleted it and re-added and it’s fine
Users browsing this forum: No registered users and 19 guests
