scokoye
LAN Connectivity Issues ccr1016-12g
Fri Jan 11, 2019 6:23 am
Dear All,
I have a Mikrotik cloud core router ccr1016-12g which is for a new LAN to cater for part of the buildings which didn't have connectivity in the past.
The original network has internet connectivity and to get internet into the new network we had to run ethernet to the Mikrotik cloud core router ccr1016-12g through the ether1 interface. The old LAN is on the 172. IP range and the new on the 192. IP range.
The new network on 192..(new) is able to access resources on 192..(new) and 172..(old) but the 172..(old) can only access resources on 172..(old) and not 192..(new)! What do I need to do to enable 172..(old) access resources on 192..(new) also?
Thank you.
Exiver
Re: LAN Connectivity Issues ccr1016-12g
Thu Jan 17, 2019 5:10 pm
First of all you need to provide more information, for example: What did you change when you implemented the CCR. Did you just add one lan cable from your old router(switch?) to the CCR? Please tell us, which configuration change was made to the existing network. And additionally it would be great to take a look at the CCR config (/export hide-sensitive).
Regards
scokoye
Sat Jan 19, 2019 5:22 am
Thanks for your response.
On the first question, Yes one lan cable from old router(switch?) to the CCR.
Secondly, no configuration change was made to the existing network.
I will post the CCR config.
Thank you again and regards.
Users browsing this forum: Bing [Bot], jweek and 129 guests
