kugla007
Unable to connect using MAC address and Winbox
Fri Jan 11, 2019 8:57 am
I've now had several MikroTik devices I couldn't connect to using Winbox and MikroTik MAC address. It doesn't even find it in the neighbors. If I plug my computer to a switch (ie. Cisco) and the MikroTik to the same switch (in the same VLAN) I can see my MikroTik device in the neighbors and I can normally connect to it.
It doesn't happen always and if I use a different computer I can connect to MikroTik just fine.
Any ideas where to start looking? It is obviously a problem with my PC but I don't know what could be the cause.
bramwittendorp
Re: Unable to connect using MAC address and Winbox
Fri Jan 11, 2019 8:34 pm
I have seen some strange behaviour with regards to neighbor discovery not working because the network interface isn't active because it has no IP-configuration. But that doesn't explain why it works when connecting trough a switch.
Bram - MikroTik enthusiast - MTCNA / MTCRE / MTCWE / MTCIPv6E
Don't be shy, share your /export hide-sensitive and make sure to read this.
Users browsing this forum: teamflores and 140 guests
