cgallery
Rb4011 issues
Fri Jan 11, 2019 8:03 pm
I have two RB4011-based devices, sourced from different locations, that I'm trying to perform initial setup on.
They both behave the same way.
If I connect my PC to ports >= 2, there doesn't appear to be any sort of DHCP server running.
When I set the IP on my NIC to 192.168.88.10, I cannot ping 192.168.88.1.
Have there been any issues with these units that would require I do something differently than normal?
I checked the instructions that were provided, it seems the method is the same as other Mikrotik gear I've setup.
I did try the reset on one of them, didn't seem to help. I have a USB to Cisco console cable on the way, figured someday I might need one and it may shed some light.
cgallery
Re: Rb4011 issues
Fri Jan 11, 2019 8:21 pm
Forget it, I figured out that they're talking to me via port #1. The instructions say to stick my connection into #1 and devices into 2...10.
Thanks anyhow.
Users browsing this forum: serveria and 66 guests
