onlineuser
Hotspot login page not loading automatically on some devices
Wed Jan 16, 2019 12:31 pm
I setup a hotspot. On most devices it works fine that the welcome (login) page will be loaded.
But on some Huawei and Samsung devices I noticed that the redirect to the login page does not work.
When I enter the hostname manually the login page will be loaded.
Does anyone know this issue?
Is there any workaround for this issue?
hugal
Re: Hotspot login page not loading automatically on some devices
Wed Jan 16, 2019 5:38 pm
It can be a HSTS issue:
https://www.wirelessphreak.com/2017/05/ ... ssues.html
do you have the same problem when accessing a http website?
The urgent is done. The impossible is in progress. For miracles, allow a delay.
trace323
Wed Jan 16, 2019 10:21 pm
There is to ways around this. It's an easy fix. I had the same issue but I was able to come up with a fix.
Thanks,
Samot
Thu Jan 17, 2019 3:47 pm
Thanks,
Are you going to share?
onlineuser
Mon Jan 21, 2019 11:04 am
http websites can be accessed without problems - also https after the client has authenticated on the hotspot website.
Yes, please share - a solution for the Mikrotik device would be fine because it would not be possible to fix every client device.
javierjose
Wed Aug 07, 2019 8:33 pm
I'm having the same issue, has someone any news on how to solve it.
onlineuser
Tue Feb 11, 2020 7:41 pm
I found no workaround.
Users browsing this forum: Anaykh, Crazyn8, mikruser, ZacharyMak and 142 guests
