shafiqrahman
How to fast track local bandwidth?
Thu Jan 17, 2019 2:44 pm
I have a hAP AC. I have three computers and few wireless devices. Can anyone tell me how do I fast track local bandwidth, so that all my local devices communicate with each other at full bandwidth?
sebastia
Re: How to fast track local bandwidth?
Thu Jan 17, 2019 2:48 pm
These devices are in same subnet? Then it's not fasttrack. Just put them in same bridge, which is probably already the case.
There should be a bridge with wlan & local ports, in it.
Edit: typo
shafiqrahman
Thu Jan 17, 2019 3:12 pm
Yes they are all in the same subnet and a bridge.
sebastia
Re: How to fast track local bandwidth?  [SOLVED]
Thu Jan 17, 2019 3:14 pm
make sure you're bridge is hardware offloaded: that needs to be enabled, and depending on setup will be applied by ROS.
shafiqrahman
Thu Jan 17, 2019 3:42 pm
Yes, it is enabled in all ether ports except the ether1 which is the internet connection.
sebastia
Thu Jan 17, 2019 4:02 pm
Then you're done!
shafiqrahman
Fri Jan 18, 2019 9:30 am
Thank You.
Users browsing this forum: simtj and 180 guests
