I've managed to create a site to site IPsec/IKEv2 connection between 2 Mikrotik device (HAP AC2 and RB4011).
Here is Router 1 (HAP AC2) config:
Code: Select all
add name=bridge1 protocol-mode=none
set [ find default-name=ether2 ] loop-protect=off name=ether2-wan1
set [ find default-name=ether3 ] loop-protect=off name=ether3-wan2
set [ find default-name=ether4 ] loop-protect=off name=ether4-wan3
set [ find default-name=ether5 ] loop-protect=off name=ether5-lan
/interface l2tp-client
add connect-to=l2tpsrv2.com disabled=no name=l2tp-out1 password=l2tppswd user=l2tpusr
add name=dhcp_pool1 ranges=192.168.88.2-192.168.88.254
add add-arp=yes address-pool=dhcp_pool1 disabled=no interface=bridge1 lease-time=2d name=dhcp1
add bridge=bridge1 interface=ether5-lan
add bridge=bridge1 interface=wlan1
add bridge=bridge1 interface=wlan2
add address=192.168.88.1/24 interface=bridge1 network=192.168.88.0
add address=112.65.129.178/30 interface=ether2-wan1 network=112.65.129.176
add address=140.206.103.134/30 interface=ether3-wan2 network=140.206.103.132
add address=220.248.18.254/30 interface=ether4-wan3 network=220.248.18.252
add address=192.168.88.0/24 gateway=192.168.88.1
set cache-max-ttl=1m cache-size=1024KiB servers=208.67.220.220,208.67.222.222
/ip firewall address-list
add address=1.0.1.0/24 list=cnlist
###...5000 more ip address list...###
add address=l2tpsrv2.com list=cnlist
add address=208.67.220.220 list=cnlist
add address=208.67.222.222 list=cnlist
add address=192.168.88.0/24 list=lan
add address=192.168.88.2-192.168.88.253 list=local
add action=accept chain=forward ipsec-policy=in,ipsec
add action=accept chain=forward ipsec-policy=out,ipsec
/ip firewall mangle
add action=mark-connection chain=prerouting in-interface=ether2-wan1 new-connection-mark=wan1
add action=mark-connection chain=prerouting in-interface=ether3-wan2 new-connection-mark=wan2
add action=mark-connection chain=prerouting in-interface=ether4-wan3 new-connection-mark=wan3 passthrough=yes
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=bridge1 new-connection-mark=wan1 passthrough=yes per-connection-classifier=both-addresses-and-ports:3/0
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=bridge1 new-connection-mark=wan2 passthrough=yes per-connection-classifier=both-addresses-and-ports:3/1
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=bridge1 new-connection-mark=wan3 passthrough=yes per-connection-classifier=both-addresses-and-ports:3/2
add action=mark-routing chain=prerouting connection-mark=wan1 in-interface=bridge1 new-routing-mark=wan1-mark
add action=mark-routing chain=prerouting connection-mark=wan2 in-interface=bridge1 new-routing-mark=wan2-mark
add action=mark-routing chain=prerouting connection-mark=wan3 in-interface=bridge1 new-routing-mark=wan3-mark passthrough=yes
add action=mark-routing chain=output connection-mark=wan1 new-routing-mark=wan1-mark
add action=mark-routing chain=output connection-mark=wan2 new-routing-mark=wan2-mark
add action=mark-routing chain=output connection-mark=wan3 new-routing-mark=wan3-mark passthrough=yes
add chain=prerouting dst-address=112.65.129.0/24 in-interface=bridge1
add chain=prerouting dst-address=140.206.103.0/24 in-interface=bridge1
add action=accept chain=prerouting dst-address=220.248.18.0/24 in-interface=bridge1
add action=mark-routing chain=prerouting dst-address-list=!cnlist dst-address-type=!local new-routing-mark=l2tp passthrough=yes src-address-list=local
add action=accept chain=srcnat dst-address=192.168.100.0/24 src-address=192.168.88.0/24
add action=src-nat chain=srcnat out-interface=ether2-wan1 to-addresses=112.65.129.178
add action=src-nat chain=srcnat out-interface=ether3-wan2 to-addresses=140.206.103.134
add action=src-nat chain=srcnat out-interface=ether4-wan3 to-addresses=220.248.18.254
add action=masquerade chain=srcnat comment=src-nat out-interface=l2tp-out1
add action=dst-nat chain=dstnat dst-address=112.65.129.178 dst-port=3999 protocol=tcp src-address-list=ssh to-addresses=192.168.88.12 to-ports=8069
add action=dst-nat chain=dstnat dst-address=208.67.220.220 dst-port=53 protocol=udp to-addresses=208.67.220.220 to-ports=5353
add action=dst-nat chain=dstnat dst-address=208.67.222.222 dst-port=53 protocol=udp to-addresses=208.67.222.222 to-ports=5353
/ip ipsec policy
set 0 disabled=yes dst-address=192.168.100.0/24 src-address=192.168.88.0/24
add dst-address=192.168.100.0/24 sa-dst-address=58.32.34.46 sa-src-address=220.248.18.254 src-address=192.168.88.0/24 tunnel=yes
/ip ipsec peer profile
set [ find default=yes ] dh-group=modp1024 dpd-interval=disable-dpd enc-algorithm=aes-256 hash-algorithm=sha256 name=shiyutech nat-traversal=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256 enc-algorithms=aes-256-gcm lifetime=1h pfs-group=none
/ip ipsec peer
add address=58.32.34.46/32 exchange-mode=ike2 generate-policy=port-strict local-address=220.248.18.254 mode-config=shiyutech passive=yes secret=ShiyuTech send-initial-contact=no
/ip ipsec mode-config
add address-pool=dhcp_pool1 name=shiyutech system-dns=no
add distance=1 gateway=112.65.129.177 routing-mark=wan1-mark
add distance=1 gateway=140.206.103.133 routing-mark=wan2-mark
add distance=1 gateway=220.248.18.253 routing-mark=wan3-mark
add distance=1 gateway=l2tp-out1 routing-mark=l2tp
add distance=1 gateway=112.65.129.177,140.206.103.133,220.248.18.253
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=ether2-wan1 type=external
add interface=ether3-wan2 type=external
add interface=ether4-wan3 type=external
add interface=bridge1 type=internal
Code: Select all
set [ find default-name=ether6 ] loop-protect=off name=ether6-lan
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether2-wan name=pppoe-out1 password=pppoepswd user=pppoeusr
add connect-to=l2tpsrv1.com disabled=no name=l2tp-out1 password=l2tppswd user=l2tpusr
add name=dhcp_pool0 ranges=192.168.100.2-192.168.100.254
add add-arp=yes address-pool=dhcp_pool0 disabled=no interface=bridge1 lease-time=4w2d name=dhcp1
add bridge=bridge1 interface=ether6-lan
add address=192.168.100.1/24 interface=bridge1 network=192.168.100.0
add address=192.168.100.0/24 gateway=192.168.100.1
set cache-max-ttl=1h cache-size=1024KiB servers=208.67.220.220,208.67.222.222
add address=208.67.220.220 comment=opendns list=cnlist
add address=208.67.222.222 comment=opendns list=cnlist
add address=l2tpsrv1.com list=cnlist
add address=192.168.100.2-192.168.100.253 list=local
add address=192.168.100.0/24 list=lan
/ip firewall mangle
add action=accept chain=srcnat dst-address=192.168.88.0/24 src-address=192.168.100.0/24
add action=src-nat chain=srcnat comment=src-nat out-interface=pppoe-out1 to-addresses=58.32.34.46
add action=masquerade chain=srcnat out-interface=l2tp-out1
add action=dst-nat chain=dstnat dst-address=208.67.220.220 dst-port=53 protocol=tcp to-addresses=208.67.220.220 to-ports=443
add action=dst-nat chain=dstnat dst-address=208.67.222.222 dst-port=53 protocol=tcp to-addresses=208.67.222.222 to-ports=443
/ip ipsec policy
set 0 disabled=yes dst-address=192.168.88.0/24 src-address=192.168.100.0/24
add dst-address=192.168.88.0/24 sa-dst-address=220.248.18.254 sa-src-address=58.32.34.46 src-address=192.168.100.0/24 tunnel=yes
set [ find default=yes ] dh-group=modp1024 dpd-interval=disable-dpd enc-algorithm=aes-256 hash-algorithm=sha256 lifetime=1h nat-traversal=no
/ip ipsec proposal
/ip ipsec peer
add address=220.248.18.254/32 exchange-mode=ike2 generate-policy=port-strict mode-config=request-only secret=ShiyuTech
add check-gateway=ping distance=2 gateway=l2tp-out1 routing-mark=l2tp
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=pppoe-out1 type=external
I've searching in the forum and found same experience posted by other users.
How can it be solved?
Thanks.
