I set the open vpn server in my microtik, it works correctly with the various clients copying the files in the configuration folder of open vpn but I have problems with the configuration on android that gives me the error there was an error attempting to connect to the selected server.
The export of the various files is done correctly and asks me when creating username and password, the problem arises when I make the connection.
Here is my .ovpn configuration file:
client
dev tun
proto tcp
remote my public ip 1194
infinite resolv-retry
nobind
persist-key
persist-tun
approx
cert client.crt
key client.key
remote-cert-tls server
cipher AES-128-CBC
auth SHA1
auth-user-pass
redirect-gateway def1
verb 3
How can I solve?
Thank you
Marco
