is there a way to log in to an SXT LTE router via MikroTik's IP cloud from an unrelated network?
The unit is obviously connected directly to the mobile provider's network, no passthrough.
Code: Select all
/ip cloud> pr
ddns-enabled: yes
ddns-update-interval: none
update-time: yes
public-address: 47.XXX.XXX.XXX
dns-name: XXXXXXXXXXXX.sn.mynetname.net
status: updated
warning: Router is behind a NAT. Remote connection might not work.
Code: Select all
add action=accept chain=input comment="Accept Winbox" dst-port=8291 in-interface=lte1 protocol=tcp
viewtopic.php?f=2&t=144141#p709293
though in that config above rule is disabled, but of course I enabled it before trying.
