Hello!
I have hAC ap router and cAP ac(arm) repeater in my house. Before that i had crappy wifi on second floor so bought this device. Now router is on 1st floor and cAP is on second and on the opposite corner of house.
Currently there is almost default settings in CAPsMAN. But sometimes the wifi isn't quite realiable as i would like to have.
So where could I improve?
When I had just router I tried one of the posts, where suggests to don't use overcrowded channels, limiting to bandwidth to 20Mhz or 40Mhz and etc, will link it here(viewtopic.php?f=13&t=130017#p638786). But what would be best home setup in capsman for those two devices, to have best signal strength and not loose much of a speed?
My current config
# jan/21/2019 16:59:22 by RouterOS 6.43.8
# software id = HI27-AU6J
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = 673705E219E9
/caps-man configuration
add datapath.bridge=bridge datapath.client-to-client-forwarding=yes name=NewHopeNet security.authentication-types=wpa2-psk \
security.encryption=aes-ccm security.group-encryption=aes-ccm ssid=NEWHOPE
/caps-man interface
add configuration=NewHopeNet disabled=no l2mtu=1600 mac-address=CC:2D:E0:AF:E2:8D master-interface=none name=cap1 radio-mac=\
CC:2D:E0:AF:E2:8D radio-name=CC2DE0AFE28D
add configuration=NewHopeNet disabled=no l2mtu=1600 mac-address=CC:2D:E0:AF:E2:8E master-interface=none name=cap2 radio-mac=\
CC:2D:E0:AF:E2:8E radio-name=CC2DE0AFE28E
add configuration=NewHopeNet disabled=no l2mtu=1600 mac-address=E4:8D:8C:6B:EE:C9 master-interface=none name=cap3 radio-mac=\
E4:8D:8C:6B:EE:C9 radio-name=E48D8C6BEEC9
add configuration=NewHopeNet disabled=no l2mtu=1600 mac-address=E4:8D:8C:6B:EE:C8 master-interface=none name=cap4 radio-mac=\
E4:8D:8C:6B:EE:C8 radio-name=E48D8C6BEEC8
/caps-man manager
set enabled=yes
