Muator
hap lite, not enough disk space.
Wed Jan 30, 2019 1:01 pm
Greetings. I can not update the firmware on hAP lite.
Through net-install the same error.
reset system does not help. fix_space.npk does not help.
sys resource pr
                   uptime: 13m2s
                  version: 6.40.4 (stable)
               build-time: Oct/02/2017 08:38:30
         factory-software: 6.40
              free-memory: 4808.0KiB
             total-memory: 32.0MiB
                      cpu: MIPS 24Kc V7.4
                cpu-count: 1
            cpu-frequency: 650MHz
                 cpu-load: 8%
           free-hdd-space: 6.0MiB
          total-hdd-space: 16.0MiB
  write-sect-since-reboot: 85
         write-sect-total: 733
               bad-blocks: 0%
        architecture-name: smips
               board-name: hAP lite
                 platform: MikroTik
[admin@Tik] > sys package update install
          channel: current
  current-version: 6.40.4
   latest-version: 6.43.8
           status: ERROR: not enough disk space, 7.2MiB is required and only 5.8MiB is free
[admin@Tik] >sys package pr
Flags: X - disabled
 #   NAME                                         VERSION                                         SCHEDULED
 0   routeros-smips                               6.40.4
 1   system                                       6.40.4
 2 X ipv6                                         6.40.4
 3   wireless                                     6.40.4
 4   hotspot                                      6.40.4
 5   dhcp                                         6.40.4
 6   mpls                                         6.40.4
 7   routing                                      6.40.4
 8   ppp                                          6.40.4
 9   security                                     6.40.4
10   advanced-tools                               6.40.4
mkx
Re: hap lite, not enough disk space.
Wed Jan 30, 2019 3:18 pm
There are rumours that on devices with tiny NAND (16MB or less, your hAP lite falls into this category) update packages are actually downloaded into RAM (which is low on your device as well). Try to reboot device (some memory might get freed). Do you have any static address lists with large number of members?
Another possibility (which would be actually benefitial for your device) would be to go to individual package installation instead of bundle - which contains a few packages you most probably don't need, such as ipv6 (you disabled it), mpls, hotspot, routing, ... You'll save some NAND space and RAM.
You can do it by downloading "extra packages" for your architecture, then only upload to router packages you really need (system, wireless, dhcp, security, ... perhaps advanced-tools ... read up package descriptions). After selected packages are successfully uploaded, reboot device (it should pick up new packages and upgrade itself).
BR,
Metod
Muator
Wed Jan 30, 2019 3:46 pm
Thanks for the answer.
Configuration reset.
I reset the configuration many times.
I tried to enable, disable, system packages, no changes occur after a reboot.
They are unchanged as shown in the post above.
This firmware is from the factory.
As soon as it was purchased, an attempt to update the firmware caused a not enough disk space.
Any attempts, including through net-install, result in a not enough disk space.
mkx
Wed Jan 30, 2019 3:56 pm
I guess it's time to ask support@mikrotik.com for advice ...
BR,
Metod
pegasus123
Thu Jan 31, 2019 12:50 pm
will netinstall help in this case?
mkx
Thu Jan 31, 2019 1:44 pm
From original post:
This sounds weird to me, but let's just assume poster tried netinstall, that it actually succeeded and he can't upgrade to newer ROS afterwards.
BR,
Metod
Wyz4k
Thu Mar 07, 2019 4:45 pm
Same problem here. Trying to upgrade hap lite to 6.43.12.
The update is 7.4MB.
I have deleted everything from files except for skins that's an empty directory.
Files reports 8.4MiB of 16.0MiB used.
I've restarted the router and tried again.
[admin@nimda] > /tool fetch url=https://download2.mikrotik.com/routeros ... .43.12.npk
status: failed
failure: cannot download: file too large, no space left on disk
Contacting support now.
sid5632
Thu Mar 07, 2019 10:14 pm
As I said on some other thread about exactly the same problem, I had to NetInstall it using the Extra packages - that allows you to remove the ones you don't want, so that upgrades will succeed next time.
I Netinstalled 6.43.12 a couple of weeks ago and I upgraded to 6.44 without problems.
chechito
Thu Mar 07, 2019 10:34 pm
1. Make a backup and export, save them on your PC
2. Disable all the packages you can including this:
hotspot
ipv6
mpls
ppp
routing
wireless
advanced tools
3. Reboot
4. Upgrade using only this packages taking them from the all packages zip:
system
security
dhcp
5. Reboot
6. After successful upgrade proceed to upgrade routerboot in system routerboard upgrade
7. Reboot
8. now install the additional packages you need only
Users browsing this forum: Bing [Bot], Google [Bot] and 89 guests
