MCI
Hotspot status.html
Thu Jan 31, 2019 10:13 pm
Hi!, thanks in advance to those who collaborate with me. =D
My questions is how to make $(uptime) updated in real time on the hotspot status page, without having to refurbish the browser.
pcunite
Forum Veteran
Forum Veteran
Re: Hotspot status.html
Tue Feb 05, 2019 5:35 am
If you don't want a page refresh, you might be able to create a JavaScript function that reads that value in a loop. I've not tested it, however.
MCI
Fri Feb 15, 2019 2:31 am
Some example of its implementation?
pcunite
Forum Veteran
Forum Veteran
Fri Feb 15, 2019 5:20 am
Replace status.html with the contents of this HTML.
<!DOCTYPE html>
<html lang="en">
<head>
    <title>Status Page</title>
    <meta charset="utf-8" />
    <meta name="viewport" content="width=device-width, initial-scale=1.0" />
    <meta http-equiv="pragma" content="no-cache" />
    <meta http-equiv="expires" content="-1" />
<script type="text/javascript">
function GetUptime()
    // Get uptime value
    var sUPTIME = '$(uptime)';
    // if sUPTIME is not parsed, show current time, simply for testing
    sUPTIME = new Date();
    // Get access to element to show uptime
    var eUptime = document.getElementById("UPTIME");
    // refresh html element
    eUptime.innerHTML = sUPTIME;
    // wait 1 second and run again
    setTimeout(function(){GetUptime()}, 1000);
</script>
</head>
<body onLoad="GetUptime()">
    <div >
        <p>Your current uptime:</p>
        <p id="UPTIME"></p>
    </div>
</body>
</html>
MCI
Fri Feb 15, 2019 10:30 am
<!DOCTYPE html>
<html lang="en">
<head>
    // Get uptime value
</script>
</head>
    <div >
        <p id="UPTIME"></p>
    </div>
</body>
</html>
pcunite
Forum Veteran
Forum Veteran
Fri Feb 15, 2019 3:01 pm
I apologize, remove these lines:
MCI
Sun Feb 17, 2019 2:22 pm
the value is still static
Thor187
Sun Feb 17, 2019 3:28 pm
Does mikrotik support javascript to its full extent?
Can I use jquery?
pcunite
Forum Veteran
Forum Veteran
Sun Feb 17, 2019 3:58 pm
The value is still static.
Then with META tags or JavaScript, you'll have to reload the page because it seems the embedded web server does not send down new data. If there is another way to query with JavaScript, I don't know how.
If we could AJAX a php file, but I don't think we can. Maybe with JavaScript AJAX, load an HTML file with the uptime in it, then parse the HTML output.
Users browsing this forum: No registered users and 54 guests
