millenium7
Anyone using Solarwinds NCM? Injecting garbage into backups
Tue Feb 05, 2019 6:56 am
We're trialing Solarwinds Network Configuration Manager but i'm noticing it's just not playing ball with MikroTik. It all seems good from the outside but I notice it's regularly throwing garbage characters into the backup files, both corrupting them and causing lots of diffs when nothings changed
i.e.
add bridge="Client PPPoE Bridge" horizon=10 [minterface=\
24:18:1D:54:6B:B9 server=[mXanDHCP
add dead-interval=4s hello-interval=1s interface=ether1 network-type=[34;1m\
It's injecting '[m' and other garbage that begins with [ into random area's of the config. Then the next backup won't have these (or will have them in different area's of the config) causing a diff
If anyone is using NCM are you getting these problems? Do you have a particular set of settings to make it work properly? Any config template edits etc?
Users browsing this forum: bagusa4 and 104 guests
