nop
how can i do iptables command in routeros?
Wed Feb 06, 2019 10:40 am
i found a linux command line
iptables -A PREROUTING -p tcp -m tcp -j DNAT -s 10.0.0.0/8 -d 211.65.64.43 --match multiport --dports 80,443,44449 --to-destination 219.230.144.123:80 -t nat
now ,how can i do it in routeros can change dst ip 211.61.64.43 to 219.230.144.123
sebastia
Re: how can i do iptables command in routeros?
Wed Feb 06, 2019 12:09 pm
# iptables -A PREROUTING -p tcp -m tcp -j DNAT -s 10.0.0.0/8 -d 211.65.64.43 --match multiport --dports 80,443,44449 --to-destination 219.230.144.123:80 -t nat
/ip firewall nat add chain=dstnat protocol=tcp action=dst-nat src-address=10.0.0.0/8 dst-address=211.65.64.43 dst
-port=80,443,44449 to-addresses=219.230.144.123 to-ports=80
nop
Sun Feb 10, 2019 7:59 am
i do this /ip firewall nat add chain=dstnat protocol=tcp action=dst-nat src-address=192.168.0.0/24 dst-port=80,443 to-addresses=123.125.115.110 to-ports=80
but i can't access 123.125.115.110 。123.125.115.110 is baidu's ip
mkx
Sun Feb 10, 2019 11:24 am
If baidu is on the internet side of routerboard, then you need src-nat rule, not dst-nat. Appropriate (for most users) rule is there by default (on most routerboard units), so if it's not working, you're messing config. To help you find the way out, you'll have to explain your topology, what you want to achieve and your current settings ... until then this would be conversation of the def ...
BR,
Metod
nop
Mon Feb 11, 2019 4:27 am
my router lan ip 192.168.0.111
my router wan pppoe
my computer ip 192.168.0.33 gateway 192.168.0.111
this is the router nat set
/ip firewall nat> pri
0 X chain=dstnat action=dst-nat to-addresses=123.125.115.110 to-ports=80
protocol=tcp src-address=192.168.0.0/24 dst-port=80,443 log=no
log-prefix=""
1 chain=srcnat action=masquerade src-address=192.168.0.0/24
out-interface=!bridge log=no log-prefix=""
123.125.115.110 is internet site.
i need when my computer access all internet 80 or 443 port can jump to 123.125.115.110.
for example, when my computer access google 443, the result I want is access 123.125.115.110.
This means that when I access the 80 443 port of any ip on the Internet, the result I visited site ip is 123.125.115.110 .
Jotne
Mon Feb 11, 2019 8:27 am
So you want a proxy?
When your inside computer tires to reach anything on the public internet on port tcp/80 and tcp/443 they should be redirected to public IP 123.125.115.110 and not the IP they get for the DNS server?
PS this may give your problems with https, since it does not work with proxy serveres. (not in any simple way at least)
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
Users browsing this forum: No registered users and 97 guests
