anav
Raw Rules
Sat Feb 09, 2019 6:55 am
Any issues with these in Raw?????????
The concept is that if one knows common ports scanned that the router does not need (the people using it dont need),
then this approach will be lighter on the CPU and yet effective. Same idea, if don't expect incoming or plan on outgoing broadcast traffic...
/ip firewall raw
add action=add-src-to-address-list address-list=DropPortProbes \
    address-list-timeout=5d chain=prerouting comment=CaptureUnusedPorts_TCP \
    disabled=yes dst-port=0,11,20,21,22,23,79,113,119,135,139,194,389,445 \
    in-interface-list=WAN protocol=tcp
    address-list-timeout=5d chain=prerouting comment=CaptureUnusedPorts_TCP2 \
    disabled=yes dst-port=\
    500,1002,1025,1026,1027,1028,1029,1030,1720,5000,8291 in-interface-list=\
    WAN protocol=tcp
    address-list-timeout=5d chain=prerouting comment=CaptureUnusedPortsUDP \
    in-interface-list=WAN protocol=udp
    address-list-timeout=5d chain=prerouting comment=CaptureUnusedPorts_UDP2 \
    WAN protocol=udp
add action=drop chain=prerouting comment=DropPortProbes disabled=yes \
    src-address-list=DropPortProbes
add action=drop chain=prerouting comment=DropIncomingBroadcasts disabled=yes \
    dst-address-type=broadcast in-interface-list=WAN
add action=drop chain=output comment=DropOutgoingBroadcasts disabled=yes \
    dst-address-type=broadcast out-interface-list=WAN
Users browsing this forum: krafg, mozerd and 29 guests
