CZFan
Re: Slow ethernet speeds with hAP AC
Sun Feb 10, 2019 12:21 am
I think the more relevant question is why do you want to make a "Router" do "Switching" function?
To use another analogy, there is a difference between cars and buses for specific reasons.
MTCNA, MTCTCE, MTCRE & MTCINE
sebastia
Sun Feb 10, 2019 2:42 am
Hey
What is the configuration of ports eth3 & 4? This will be relevant concerning the speed you can get.
Given the block diagram https://i.mt.lv/cdn/rb_files/RB962UiGS-160210082257.png, if these are switched, you should be getting wirespeed. If these are routed you'll be limited to 1gb/s total.
Users browsing this forum: krafg and 33 guests
