karwos
Beware using Winbox v3.x with ROS v5.x devices
Sun Feb 10, 2019 10:31 pm
Yes, we know 5.x is legacy systems, but since they were extremely stable, we secured them well and held upgrade process, seems will need to little speedup that.
Don't use Winbox v3.11 with v5.x systems.
They aren't properly closing Winbox sessions and when you open users->active session you will get plenty active sessions.
They are garbage sessions: TCP/IP connections was of course already closed.
Problem is: they consume CPU and such junk session is causing memory leak which is leading to Denial-of-Service condition. Bye bye stable 5.x. Thanks to Mikrotik.
That problem was marked already in 2016: viewtopic.php?t=113623 but of course "it will be fixed someday so you can remove junk sessions without reboot".
And no, I have no balls spawning devel login and trying to restart mgmt process on production machine :D
Jotne
Forum Veteran
Forum Veteran
Re: Beware using Winbox v3.x with ROS v5.x devices
Mon Feb 11, 2019 8:34 am
I seems that MT has removed support for 5.xx in later version of Winbox
What's new in v3.13:
*) abandoned support for connecting to older RouterOS versions (older than v6), no DLLs will ever be downloaded;
*) winbox.exe is now signed executable;
It may be time to do an upgrade of your devices..
Use Splunk to monitor your MikroTik Router
MikroTik->Splunk
Users browsing this forum: someone2 and 36 guests
