vklpt
Port knocking with URL
Mon Feb 18, 2019 4:14 pm
Let's call it «Web Knocking».
The idea is simple - we open the ports just by clicking on the link.
This is a web server that sends IP addresses of valid requests to the white list and IP addresses of bad requests to the black list:
https://github.com/vikilpet/Web-Knocking
sebastia
Re: Port knocking alternative
Mon Feb 18, 2019 9:48 pm
Goal of port knocking is to keep it hidden to public except the ones in the know. But at least easy to use.
vklpt
Tue Mar 05, 2019 7:31 pm
Update:
• New ini parameter: url_prefix
tippenring
Wed Mar 06, 2019 6:28 pm
Besides being less practical than nping, I suspected the executable might be malicious. VT Detection ratio: 11 / 70
Check VirusTotal: https://www.virustotal.com/en/file/d81c ... /analysis/
vklpt
Wed Mar 06, 2019 8:53 pm
You did not get the idea.
If you believe in power of heuristic algoritms of noname antiviruses you better not use winbox too:
https://www.virustotal.com/#/file/b300a ... /detection
vklpt
Re: Port knocking with URL
Mon Apr 13, 2020 7:59 pm
The code is now publicly available.
It also may work with non-routeros devices with help of netmiko but i have MikroTik's only.
jvanhambelgium
Mon Apr 13, 2020 8:58 pm
Although I understand the idea, there is a couple of possible issues.
- Continuous open-to-anyone-everywhere attack-vector of the DNAT-entry pointing to your web-page.
- Un-encrypted "admin" credentials in the Python files ; if ever compromised you have full power on the Mikrotik
- Only 1 "stage" , meaning making the request to the correct URL and you are in.
I also use port-knocking in a 3-stage setup, meaning 3 knocks are required (random ports, mix of UDP/TCP), within a certain time-frame (seconds) to give access for a specified duration.
Much,much more secure, I would say near impossible to "guess" it and there is no permanent "patchhole" like you have pointing to your Phythong webserver.
Any smartphone could run such app where you can pre-configure the knocking-sequence. If your user is eg. sitting in a hotel he can use the Hotel Wifi and perform the sequence, then the laptop (also connected on Hotel-wifi) probably uses the same public-IP and is therefore also usable. (same applies if at home)
Or the use could use his phone on 4G in "tethering" mode and act as wireless AP for the laptop to work on after sequencing the port-knock.
The alternative offcourse is "VPN" ;-)
Jotne
Mon Apr 13, 2020 9:41 pm
I do not see the need of a URL to port knock. I will add more components to run the network.
To use normal port knock, you do not need any tools if its TCP to open the ports.
Eks port 1600, 2500 and 3456 needed to open.
Then from any browser open following pages in sequences.
http://router_os.ip:/1600
http://router_os.ip:/2500
http://router_os.ip:/3456
How to use Splunk to monitor your MikroTik Router(s)
MikroTik->Splunk
jvanhambelgium
Mon Apr 13, 2020 11:12 pm
Offcourse this will work too, but nice simple Windows, Android & IOS apps exist where 1 press of a button starts the sequence, putting some custom timers where needed etc.
In your case you need some favorites URL's stored or something, especially if you expect the sequences to arrives within max 1 or 2 seconds apart.
Many solutions exist.
vklpt
Wed Apr 15, 2020 9:38 pm
v2020-04-15
+ Logging to a file
Jotne
Wed Apr 15, 2020 10:33 pm
Syslog is the best way (at least for me) to handle logs.
MikroTik->Splunk
vklpt
Mon Apr 20, 2020 6:02 pm
v2020-04-20
new logging format
vklpt
Thu Apr 23, 2020 1:29 pm
v2020-04-23 + hotkeys
Users browsing this forum: brixsat, rofrigo2, sarakarumneha, sindy and 74 guests
