YuriS
Road Warrior (Remote Access) using IPSec IKEv2 with cert authorization for multiple users
Wed Feb 27, 2019 4:02 pm
Good day.
Mikrotik RB3011UiaS with RouterOS 6.43.12. in use.
Just introduced IPSec IKeV2 Remote Access with certificate authority for one test user.
Everything work fine, kindly obtain configuration settings
/ip ipsec peer profile
add dh-group=modp1024 enc-algorithm=aes-256 hash-algorithm=sha256 lifetime=8h name=phase1_ra_win10
/ip ipsec policy group
add name=remote_access
/ip ipsec proposal
add enc-algorithms=aes-256-cbc lifetime=1h name=phase2_ra_win10 pfs-group=none
add name=Adv-RemoteAccess-pool ranges=192.168.20.2-192.168.20.62
ip ipsec mode-config
add address-pool=Adv-RemoteAccess-pool address-prefix-length=26 name=r_access_cfg split-include=192.168.40.0/26
/ip ipsec peer
add address=0.0.0.0/0 auth-method=rsa-signature certificate=vpn.server \
    comment="Remote Acces - Yuri S" exchange-mode=ike2 generate-policy=\
    port-strict mode-config=r_access_cfg passive=yes policy-template-group=\
    remote_access profile=phase1_ra_win10 remote-certificate=yuri.s \
    send-initial-contact=no
/ip ipsec policy
set 0 comment="Remote Access (Road Warrior)" dst-address=192.168.20.0/26 \
    group=remote_access proposal=phase2_ra_win10 src-address=0.0.0.0/0
but got error "This entry is unreachable" when trued to setup another user for Remote Access.
Even if I ignore this error Remote Access stop working
Looking in Mikrotik Wiki and Google but no luck.
My mail goal is to setup Remote Access based on IPSec IKeV2 with certificate authorization for multiple (may users). Each user must has own personal certificate. Is it possible create this configuration on Mikrotik?
Where is my mistake?
Best regards.
Best regards,
Yuri.
YuriS
Re: Road Warrior (Remote Access) using IPSec IKEv2 with cert authorization for multiple users
Mon Mar 04, 2019 10:38 am
Good day.
I found where issue was. I updated my Miktorik to 6.44. and configured Remote Access according this article
https://wiki.mikrotik.com/wiki/Manual:I ... entication
Everything works fine.
Best regards,
Yuri.
Users browsing this forum: Bing [Bot], Yahoo [Bot] and 96 guests
