neutronlaser
HTTP speed test
Sat Mar 02, 2019 2:52 am
Make a HTTP speed test tool
anav
Re: HTTP speed test
Sat Mar 02, 2019 6:22 pm
Wrong forum.
Suggest download speedtest app.
or check out new capability in 6.44!!
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
neutronlaser
Re: HTTP speed test
Sun Mar 03, 2019 3:48 pm
Correct forum.
Both useless suggestions.
anav
Re: HTTP speed test
Sun Mar 03, 2019 6:22 pm
You requested a feature, try the forum which states........
"RouterOS v6 RC and v7 BETA
BETA Testing and Feature Suggestions for the next RouterOS release (ROS v7)"
Can't miss it - as its top of the Forum list!
What's new in 6.44 (2019-Feb-25 14:11):
MAJOR CHANGES IN v6.44:
!) cloud - added command "/system backup cloud" for backup storing on cloud (CLI only);
!) ipsec - added new "identity" menu with common peer distinguishers;
!) ipsec - removed "main-l2tp" exchange-mode, it is the same as "main" exchange-mode;
!) ipsec - removed "users" menu, XAuth user configuration is now handled by "identity" menu;
!) radius - initial implementation of RadSec (RADIUS communication over TLS);
!) speedtest - added "/tool speed-test" for ping latency, jitter, loss and TCP and UDP download, upload speed measurements (CLI only);
Also there is this.....
https://www.speedtest.net/apps
What are you requesting that cannot be accomplished by the new feature or the apps??
neutronlaser
Re: HTTP speed test
Mon Mar 04, 2019 12:27 am
Only tests from weird custom server that is not available for linux
BRMateus2
Re: HTTP speed test
Mon Mar 04, 2019 4:47 am
Well, HTTP speed tests are all by an specific protocol - Speedtest.net for example, is very different from Btest, which is very different from any open source Python server and client.
There does not exist any HTTP Speed Test as you want, it does not work magically in computer science and protocols, and never will, because the standards are there and only mainstream follow.
Users browsing this forum: Adelomer, yonesmit and 109 guests
