mogul
dynamic ip in a dst-nat rule
Sun Mar 03, 2019 4:28 pm
Using a RB450G (sw 6.43) in front of my home networks. Im on a cable connection where I get assigned a new Ip address once in a while. I have a dyn-dns service to follow me around.
One of the machines is a docker host with a bunch of web services on, all having individual public DNS records.
I would like these services accessible both from the outside world, but also from the inside.
To make this I have the following dst-nat rule:
add action=dst-nat chain=dstnat \
  dst-address=88.77.66.55 dst-port=80,443 \
  to-addresses=192.168.40.13
where 88.77.66.55 is my current public IP.
Now when my provider moves me to a new IP, I have to manually go in and do a
/ip address print
and then update the IP in the NAT rule above.
Question is if I somehow can say to the dst-address in the NAT rule "use the address you got assigned on ether1" ?
anav
Re: dynamic ip in a dst-nat rule
Tue Mar 05, 2019 1:55 pm
in-interface=eth1wan or if you have several wans, in-interface-list=wan (instead of IP addresses)
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
Steveocee
Tue Mar 05, 2019 5:32 pm
This won't be totally applicable but it explains how to get the dynamic bit down far easier than my typing will do.
https://www.youtube.com/watch?v=_kw_bQyX-3U
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
anav
Tue Mar 05, 2019 6:56 pm
For inside connections to your own servers (but for some strange reason want to use the public wan ip address) the typical answer is to use hairpin-nat.
There is another option i don't quite understand but it has to do with routing the traffic............ directly to the server.
/ip route rule
add action=lookup dst-address=<an IP not sure which one???> table= main?????
2frogs
Long time Member
Long time Member
Tue Mar 05, 2019 8:25 pm
I prefer this nat rule over using the ddns shown in the video.
add action=dst-nat chain=dstnat dst-address-type=local dst-address=!192.168.40.1(or router ip) dst-port=80,443  to-addresses=192.168.40.13
nostromog
Wed Mar 06, 2019 1:53 am
In a separate thread somewhere around I read that one way would be:
* activate /ip cloud set ddns-enabled=yes update-time=no (for time it is better to use ntp)
* create a mypublicip firewall address.list with the <serialname>.sn.mynetname.net dns name: /ip firewall address-list add address=[/ip cloud get dns-name] list=myip
* use this address list in the firewall rules, substituting dst-address=88.77.66.55 -> dst-address-list=mypublicip
You obviously could do the same with whatever dynamic dns you are using, instead... Works quite well in practice
Users browsing this forum: No registered users and 95 guests
