rzirzi
ROS 6.44 - VPN L2TP not working
Mon Mar 04, 2019 1:57 pm
After upgrade from ROS 6.43.12 to 6.44 - I have lost possibility co connect to my MT with L2TP (with preshared key) VPN. I was changing firewall settings, trying other.... but after downgrade to 6.43.12 - IT WORKS AGAIN. So something is BAD with ROS 6.44 and L2TP VPN ! MikroTik team - please repir that ROS 6.44 BUG.
Sarel0092
Re: ROS 6.44 - VPN L2TP not working
Mon Mar 04, 2019 6:48 pm
I found that simply disabling and re-enabling the L2TP server resolved the problem.
/interface l2tp-server server set enabled=no
/interface l2tp-server server set enabled=yes
Kindis
Mon Mar 04, 2019 7:19 pm
Works like a charm for me. What did the log say?
Also did you try a reboot again after the upgrade? I always reboot twice after a upgrade. Once for the upgrade and another for the firmware. If there was a issue with this during the first boot I would not have noticed.
eddieb
Mon Mar 04, 2019 9:05 pm
Hmm, my site-to-site tunnels where converted correcty, but my roadwarrior PSK does not work anymore ...
"parsing packet failed, possible cause: wrong password"
until 6.43.12 it worked ok
Running 6.47 (stable) on :
CCR1009-8G-1S (2x ipsec/l2tp site-to-site, ipsec/l2tp roadwarrior, dhcpd, dns), CRS125-24G-1S, RB1100, RB962UiGS-5HacT2HnT (10pc), RB931-2nD, RB951, RB750GL ,RB2011UAS-RM, RB750Gr3 running dude
Vaxter
Tue Mar 05, 2019 2:24 am
Strange behavior, but this works for me!
Tnx!
rzirzi
Tue Mar 05, 2019 8:18 am
Really strange, but after "second upgrade" (this night) to ROS 6.44 - it works OK. VPN is connecting.
emils
Tue Mar 05, 2019 8:39 am
The issue will be fixed in the next RouterOS release.
baragoon
Tue Mar 05, 2019 8:50 am
universal answer :lol:
eddieb
Tue Mar 05, 2019 8:52 am
@emils nice that this problem is allready known.
in my case below is the relevant part of the config :
add name=dyn-vpn ranges=192.168.88.2-192.168.88.19
/ppp profile
add change-tcp-mss=yes dns-server=192.168.88.1 local-address=192.168.88.1 \
    name=ppp-in only-one=no remote-address=dyn-vpn use-encryption=required \
    use-ipv6=no use-mpls=no
set allow-fast-path=yes authentication=mschap2 default-profile=ppp-in enabled=yes ipsec-secret=SERVERPASS max-mru=1460 max-mtu=1460 use-ipsec=yes
/ppp secret
add name=dynuser1 password=DYNUSER1PASS profile=ppp-in
this creates a dynamic ipsec peer as in the documentation ( https://wiki.mikrotik.com/wiki/Manual:Interface/L2TP )
It worked nice until ros 6.43.12 but in 6.44 I get "parsing packet failed, possible cause: wrong password"
rzirzi
Tue Mar 05, 2019 8:53 am
But - there is answer! They found bug and will repair it - it's important that they looking for... and repairing.
Chupaka
Tue Mar 05, 2019 12:07 pm
What's new in 6.45beta6 (2019-Mar-05 08:51):
*) ipsec - fixed dynamic L2TP peer and identity configuration missing after reboot (introduced in v6.44);
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
eddieb
Tue Mar 05, 2019 12:24 pm
Hopefully we won't have to wait to long for this fix in current ...
eddieb
Tue Mar 05, 2019 2:15 pm
I tried this beta but it did not solve my problems ... L2TP server with PSK is not working
rzirzi
Tue Mar 05, 2019 2:17 pm
Please write to support@mikrotik.com with .rif file attached.
eddieb
Tue Mar 05, 2019 2:35 pm
done ;-)
eddieb
Tue Mar 05, 2019 3:35 pm
that was FAST ! Emils thanks for your help !!!
it seems the way dynamic peer configuration from L2TP server were added to the peers menu changed between 6.43.12 and 6.44
dynamic peers take precedence BEFORE static peer entries ...
In my case there was a static default PEER with a password used by all my roadwarrior clients.
The dynamic peer (from the L2TP server entry) had a typo in the password but that never was used.
until now ...
changed the password and all my clients are working again !
kudos to support, extra kudos to emils
thanks
yacsap
Thu Mar 14, 2019 5:22 am
Could you please have a look at my issue:
viewtopic.php?f=2&t=146418
Can you please confirm if the issue is same and will be fixed on next version release as well?
Cheers
[ IMikroTik ] >
emils
Thu Mar 14, 2019 8:52 am
yacsap
Thu Mar 14, 2019 11:12 pm
If I upgrade to 6.44.1 will it fix the issue without changing the config?
[ IMikroTik ] >
gotsprings
Forum Veteran
Forum Veteran
Fri Mar 15, 2019 12:00 am
Upgrading 6.44.1 broke my firewall forwarding chains.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
Chupaka
Fri Mar 15, 2019 11:45 am
In what way?
routiti
Sat Mar 23, 2019 1:00 pm
Since I upgraded to 6.44.*, I currently have patch 6.44.1 and device CCR1036-12G-4S, can not connect Windows 10 clients with IPSEC, get error when trying to connect and I have not changed at all the configuration in the clients or router
JohnTRIVOLTA
Sun Mar 24, 2019 10:17 pm
I have the same problem. I reverted it with version 6.43.13 LT and L2TP with ipsec works again ! The routerboard is RB750Gr3 !
Second problem - RB4011 as l2tp / ipsec client does not connect to hAP AC2. If I remove the tick for using ipsec the router establish the connection without encoding, although hAP AC2 /server side/ is using IPSEC - have the tick use ipsec ! .
zuzkins
Wed Apr 24, 2019 9:43 am
until now ...
thanks
Thanks for posting the way to resolve your problem. I also had the same issue (mismatch of shared secrets between IPSEC and L2TP server identities), using the correct pre-shared key works as a charm.
obie
Sat Jan 18, 2020 10:34 pm
It Worked !!!
My ROS 6.46
sparrow
Mon Jan 27, 2020 10:45 am
Just replace your IPsec "Secret" into L2TP server configuration "IPsec Secret" and it will work. I had the same trouble and I solved it!
MTCNA - MTCRE - MTCWE
take
Sat Mar 14, 2020 10:44 pm
I've got this right after a leap upgrade from 6.43.x to 6.46.4 while trying VPN clients to connect upgraded router:
And of course I've got all my L2TP connections dropped and could not be established.
So due to your kind replies I've fixed it few minutes ago as follows:
PPP-->Interface-->L2TP Server
Use ipsec = yes
IPsec Secret = [put old or new password]
I put the new one so I have had to update it on all devices connecting to the router via L2TP
thats all!
Users browsing this forum: cbpapi, CZFan, Google [Bot], xvo and 43 guests
