MUM Europe 2020
fpascual
Port
Wed Mar 21, 2007 2:23 am
Where can I define other ports than /ip service ?, I`m trying to configure port knocking in port 48220 but can`t define them.
Thanks.
JJCinAZ
Wed Mar 21, 2007 7:56 am
The /ip service items are really control of daemons on the router to provide services, like the web interface or the ftp server. You really want to use a firewall rule (or rules) with a specific port and action 'add src address to list' to allow in the knocking user.
janisk
Wed Mar 21, 2007 12:38 pm
indeed, /ip firewall filter is your answer and just use action - add src to list
fpascual
Sat Mar 24, 2007 8:44 am
Yes, I tried to use /ip firewall filter with a different ports but doesn`t work.
Can you paste me an example please ?.
Thanks a lot.
JJCinAZ
Sat Mar 24, 2007 4:54 pm
You need to have a cascade of rules for example:
UDP port 2021 -> add src to list A
UDP port 2022 and src is on list A -> add src to list B
UDP port 2023 and src is on list B -> add src to list ALlowed
fpascual
Wed Apr 04, 2007 9:28 pm
Yes, but I want to do a port knocking only one port.
Permit List A for 15 minutes
Then, I must use telnet to this port ?? (like "telnet 192.168.1.1 2021")
In this momento I use port knocking but with http port ....
Thanks !.
JJCinAZ
Thu Apr 05, 2007 10:09 pm
It would be more like:
UDP port 2021 -> add src to list A with 15 min timeout
Permit list A
fpascual
Thu Apr 05, 2007 10:50 pm
Take a look please:
19 ;;; Permito SSH - Port Knocking SSH - Interface Externa
chain=input in-interface=externa dst-port=2021 action=add-src-to-address-list address-list=ssh_ok
address-list-timeout=15m
20 ;;; Acepto SSH Verificado - Port Knocking
chain=input in-interface=externa protocol=tcp dst-port=22 src-address-list=ssh_ok action=accept
21 ;;; Logueo Resto Intentos SSH
chain=input protocol=tcp dst-port=22 action=log log-prefix="ssh_denegado"
22 ;;; Dropeo Resto SSH
chain=input protocol=tcp dst-port=22 action=drop
Then, from remote computer I put:
c:\telnet my_router 2021
... and the rule does´t match, the remote IP doesn`t appear in ssh_ok list.
What I`m doing wrong ?.
Thanks !
JJCinAZ
Thu Apr 05, 2007 11:28 pm
Permit list A
JJCinAZ
Fri Apr 06, 2007 11:37 pm
You need a protocol specification. The rule cannot look into the IP packet to get a port until it knows if it's a TCP, UDP, etc. Try the following:
chain=input in-interface=externa protocol=tcp dst-port=2021 action=add-src-to-address-list address-list=ssh_ok
fpascual
Sat Apr 07, 2007 2:40 pm
JJCinAZ, doesn`t work ...
skillful
Trainer
Trainer
Sat Apr 07, 2007 5:03 pm
Try this rule:
add chain=input in-interface=externa protocol=udp dst-port=2021 action=add-src-to-address-list address-list=ssh_ok \
comment="Permito SSH - Port Knocking SSH - Interface Externa" address-list-timeout=15m
Make sure to place this rule above any rule that block inputs to the router.
fpascual
Sat Apr 07, 2007 5:19 pm
No skill ...
Take a look of my firewall rules:
[admin@mk] ip firewall filter> print input
0 ;;; Permito SSH desde la LAN
chain=input in-interface=interna src-address=192.168.1.0/24 protocol=tcp dst-port=22 action=accept
1 ;;; Permito SSH - Port Knocking SSH - Interface Externa
chain=input in-interface=externa protocol=udp dst-port=2031 action=add-src-to-address-list address-list=ssh_ok
address-list-timeout=5m
2 ;;; Acepto SSH Verificado - Port Knocking
3 ;;; Logueo Resto Intentos SSH
4 ;;; Dropeo Resto SSH
Then, from a remote computer:
C:\Documents and Settings\>telnet my_mk 2031
Connecting To my_mk...Could not open connection to the host, on port 2031: Connect failed
And nothing happend:
ip firewall address-list> print
Flags: X - disabled, D - dynamic
# LIST ADDRESS
Thanks a lot.
tneumann
Sat Apr 07, 2007 5:44 pm
fpascual,
you defined the 'knocking' to port 2031 with UDP, but telnet uses TCP, hence you can not use a telnet to port 2031 to do the knocking...
You'd need a special tool that sends a UDP packet to port 2031, or change the knocking rule to use TCP, then you can use telnet just like you did.
--Tom
skillful
Trainer
Trainer
Sat Apr 07, 2007 5:50 pm
This command will telnet to "my_mk" on TCP port 2031 whereas, the router is listening on UDP port 2031. So, the source IP will not be added to "ssh-ok". You must knock on UDP port 2031 for this to work. Alternatively, change the protocol to TCP in your rule 1, then the telnet command will work.
skillful
Trainer
Trainer
Sat Apr 07, 2007 5:54 pm
tneumann took the words out of my mind :)
fpascual
Sat Apr 07, 2007 6:22 pm
Yes, before I try with TCP and doesn`t work.
Is correct use "telnet mk_ip port" to activate knocking ???, I think this is my problem.
Thanks to all.
Users browsing this forum: mmastrac and 129 guests
