SergeyFrolov
hAP ac² white color
Thu Mar 07, 2019 6:39 am
Hello, friends.
I have long wanted to buy hAP AC2. This router with excellent capabilities. It seems to me that the only thing he lacks is a white model. Tell me, is it planned to make a white version? Thank.
chechito
Re: hAP ac² white color
Thu Mar 07, 2019 3:46 pm
Hello, friends.
if your case of use is for access point an option is the cAP-AC that comes in white, almost same specs like hAP-ac2
vecernik87
Long time Member
Long time Member
Thu Mar 07, 2019 10:22 pm
instead of just white color, I would prefer rather old boxy design which had way better LED indicators as well as thermal properties.
deanMKD1
Fri Mar 08, 2019 12:19 am
Mikrotik for SOHO department never have white case for their products, so suppose no that will not have white color cases.
neutronlaser
Fri Mar 08, 2019 1:55 am
HAP AC better than HAP AC2 and is white.
vecernik87
Long time Member
Long time Member
Fri Mar 08, 2019 3:49 am
Thats so untrue. Until 2 years ago, there was not a single black SOHO product. (first was RB931-2nD, followed by RB952Ui, RBD52G and finally RB760iGS which is quite unique because it has old boxy design, yet it is black)
That depends what parameters you compare.
hAP ac^2 has way more CPU power which is necessary for any routing/firewalling/queuing. Similarly it has HW support for IPsec encryption and double bandwidth between switch chip and CPU
On the other hand hAP ac has SFP, better wifi and a beeper...
In overall I would say ac2 is better, unless you require SFP or 3 chain wifi...
Users browsing this forum: xvo and 28 guests
