MUM Europe 2020
ashisheitl
How It is POSSIBLE
Wed Mar 21, 2007 9:02 am
I have Master MT with Public & Private IP with Transpaent proxy configured.
Just i check the /ip neightbour LIST.
Some TWO Phone server is showing in that list with MT 2.8.24, I have all MT 2.9.29 in my Network,
How it is POSSIBLE...???
ASHISH
janisk
Wed Mar 21, 2007 10:13 am
try to connect to those v2.8 MT and see what's wrong
ashisheitl
Wed Mar 21, 2007 10:22 am
I am NOT able to connect the BOTH MT 2.8
ASHISH
janisk
Wed Mar 21, 2007 10:33 am
and are you sure that these are your routers?
ashisheitl
Thu Mar 22, 2007 4:55 am
NO SIR,
Its NOT my Routers, n in my network all are 2.9.29.
ASHISH
janisk
Thu Mar 22, 2007 10:07 am
then where is the problem?
mikrotik discovery protocol is working, check if they are inside your network or outside. this is possible to see all the MT routers that have not his protocol disabled
ashisheitl
Thu Mar 22, 2007 1:01 pm
JANIX,
The Both router are NOT from network but still it is showing in my neighbour LIST.
and again i dont have 172.16 series in my network.
How it is coming....Just let me know
tneumann
Thu Mar 22, 2007 3:18 pm
The Mikrotik Discovery Protocol operates on layer 2 and is indenpendant from IP addresses. It appears that there are other Mikrotik devices (owned and operated by another ISP) in the same broadcast domain as your devices. If you're using a shared network that you and the other operators agreed on using cooperatively then this is just fine. If you're operating a closed network of your own then these other devices should not be connected to your networks - or you not to theirs :)
--Tom
Users browsing this forum: armelachie, MSN [Bot] and 106 guests
