davidreaton
Another ROS upgrade, Another bricked hAP ac
Wed Mar 13, 2019 6:56 pm
I just upgraded several Mikrotik products (951G, 3011, CCR1016-12G and hAP ac) to ROS 6.44. As has happened several times in the past, one of the hAP acs bricked and went into the 'boot loop' many of us have seen. I went to Netinstall to bring this unit back to life, with MANY failed attempts. Finally, I inserted a gigabit switch between the PC and the hAP ac, and got Netinstall to work. In the past I've recovered 6 of this model with Netinstall, and had to RMA three others that were too far gone. No problems at all with any other Mikrotik models.
Has anyone else had this problem with the hAP ac units? Does this unit have some hardware design issues? Since I use these exclusively as APs, I don't think I'll buy any more of these in the future. I'll go with the newer cAP ac line.
neutronlaser
Re: Another ROS upgrade, Another bricked hAP ac
Wed Mar 13, 2019 8:56 pm
Mine keeps losing all its wireless interfaces on reboot and I have to do factory reset.
deanMKD1
Thu Mar 14, 2019 12:58 am
I upgraded mine hAP AC2 without any problem ..
vecernik87
Forum Veteran
Forum Veteran
Thu Mar 14, 2019 7:53 am
I noticed similar behavior on hAP ac^2 and according to support, it was caused by graphing enabled -> try to disable graphing on your wifi interfaces and give it try again :) maybe it won't disappear after reboot.
eddieb
Thu Mar 14, 2019 8:06 am
I have 10 hAP AC (RB962). Updating to every stable update for the last 2 years, never had any problems.
Running 6.47.2 (stable) on :
CCR1009-8G-1S (2x ipsec/l2tp site-to-site, ipsec/l2tp roadwarrior, dhcpd, dns), CRS125-24G-1S, RB1100, RB962UiGS-5HacT2HnT (10pc), RB931-2nD, RB951, RB750GL ,RB2011UAS-RM, RB750Gr3 running dude
Users browsing this forum: Baidu [Spider], sami19002006, sindy and 66 guests
