Tue Mar 19, 2019 10:49 pm
Export file:
# mar/19/2019 17:46:52 by RouterOS 6.44.1
# software id = 5K3K-F73B
# model = 1100
# serial number = 2C6B016B85C8
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] speed=100Mbps
set [ find default-name=ether7 ] speed=100Mbps
set [ find default-name=ether8 ] speed=100Mbps
set [ find default-name=ether9 ] speed=100Mbps
set [ find default-name=ether10 ] speed=100Mbps
set [ find default-name=ether11 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether12 ] advertise=\
set [ find default-name=ether13 ] advertise=\
/ppp profile
set *0 dns-server=195.128.124.181,195.128.124.150
add address=****/28 interface=ether3 network=****
add address=192.168.4.200/24 interface=ether4 network=192.168.4.0
set servers=195.128.124.181,195.128.124.150
add action=drop chain=input dst-port=5060 protocol=tcp
add action=drop chain=input dst-port=2000 protocol=tcp
add action=drop chain=input dst-port=5060 protocol=udp
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
add distance=1 gateway=****
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=America/Sao_Paulo
/system watchdog
set watchdog-timer=no
