bigcw
Is the bridge admin mac "random"?
Wed Mar 20, 2019 12:06 am
Reason for asking: I need to generate a random password. It doesn't have to be particularly secure, just different from most of the others
There seems to be a few methods of generating random passwords on here but most are lengthy and complicated bits of code. However it looks to me like if a bridge is created with no port members it is given a random MAC address. For example:
If this is really 'random' (or at least random enough that it is unlikely another router will pick the same MAC) this seems like a very simple way of generating a string of characters to use as a password. Just remove the ':', perhaps covert to lower case, and you are good to go.
Anyone care to comment on the suitability this solution?
Ecom International Network - Operators of AS61337 with POPs in Europe and North America - www.ecomltd.co.uk
Colocker Data Centre - The data centre with a difference! - www.colocker.com
bigcw
Re: Is the bridge admin mac "random"?
Wed Mar 20, 2019 12:47 am
Little bit of proof of concept code. Much simpler than the other methods I have seen in the past!
/int bridge add name=getrandom
local mac [ /interface bridge get getrandom mac-address]
local random ([pick $mac 0 2].[pick $mac 3 5].[pick $mac 6 8].[pick $mac 9 11].[pick $mac 12 14].[pick $mac 15 17])
/int bridge remove [find where name=getrandom]
put ($random)
Generates random 12 character hex strings...
[admin@testrouter] /system script> run 0
E68B967243F9
DE8BECA8439E
16758A0106A3
6603281BF8F3
1AEA11A3ABBA
BE53E9752A0F
6E038C84DDB6
C2115E44B371
3E57E98768FF
8A3A36769430
0A68EF57CD5E
2E5B8A327A7C
DE88F5BAA8E3
FAD85BB20925
mkx
Wed Mar 20, 2019 8:56 am
Generally one can not just randomly pick up a MAC address
If you look at MAC addresses in your screenshot, you'll notice that they are not entirely random: every listed MAC address has 7th bit (counting from most significant bit, i.e. from left) in first (most significant) octet set to 1. Which denotes a locally administered MAC address. Those are free to pick, but still have to be unique inside ARP domain (i.e. IP broadcast domain, i.e. same subnet).
My observation (which may be wrong though) is that (at least recent versions of) ROS picks a "random" MAC address by taking a real MAC address present on the device and changing the first octet so that it becomes locally administered. E.g. when a virtual AP is constructed on top of real wifi device, MAC for VAP will be similar to MAC of real device, but from locally administered MAC address range.
BR,
Metod
Users browsing this forum: Google [Bot] and 76 guests
