zsolt
OpenWRT on Mikrotik
Sun Mar 24, 2019 3:39 pm
The RouterOS IPv6 support is not enough for me, so I need Linux kernel 4.x functions. The OpenWRT 18.06.2 use Linux kernel version 4.9 or 4.14.
I found a list, which devices are supported: https://openwrt.org/toh/start?dataflt%5 ... D=MikroTik
How do I install OpenWRT?
How do I reinstall the RouterOS if I don't like it? How do I save the original license key? Other important?
sebastia
Re: OpenWRT on Mikrotik
Sun Mar 24, 2019 6:56 pm
This is not an OpenWRT forum...but you can export / import licence through system menu.
Regarding install check their forums, but probably some variation on netinstall process.
mistry7
Sun Mar 24, 2019 7:13 pm
Most devices (exclude ARM based) are more or less supported...
Switching between ROS and OpenWRT is not the much work.......
Users browsing this forum: No registered users and 47 guests
