I want to establish an EoIP tunnel between NA and Europe. The issue is the Europe connections is behind a vodafone router/modem.
I am not sure if it can be put in bridge mode or not. Further it might be providing TV and telephone and thus something an MT router probably cannot replicate.
So my question is, can I attach a MT router behind the Vodafone unit and still establish an EoIP tunnel. I read that both have to be routable?
For example, on the vodafone it is capable of forwarding ports. So if the MT device is on the LAN provided by the vodafone unit, what ports would I need to forward to the MT device (47?)
I'm assuming I would keep the MT in router mode (its WANIP is identical to the LANIP given out by the vodafone etc.). Is this possible or forget about it?
+ lets say I can proceed
Do both WANIPs have to be static? Do I need ddns names if dynamic?
Is having the EoIP tunnel encrypted necessary for all situations, for example between two homes?
What if one only uses tunnel id?
I originally thought that one of the routers would provide dhcp on the eoip tunnel but it seems both sides use the point to point /30 setup or is this just two options of many???
Are there actual ethernet interfaces involved?? Or is that only when you want to attach physical devices to the tunnel (such as an NAS to share files or perhaps an AP so that you can access the tunnel wirelessly from a laptop? In other words why assign ethernet interfaces to EOIP associated bridges??
I understand that ethernet interfaces are not necessarily needed because one can create static routes across the tunnel. Such as location 2, putting in LAN1 subnet as destination address through the applicable eoip tunnel gateway and vice versa, in effect being able to access LANS across the tunnel. I guess this means firewall rules do not apply and that connectivity is established using routes if one wants to share lan access?? Otherwise all tunnel users stay on tunnel LAN and any connected etherport devices??? What kind of an IP address would a PC get connected to such an etherport??? Okay if your lans are on bridges and you want to be able to share lans, the eoip tunnel also has to be on the same bridge?
In other words more confused than enlightened.
