Neurotox
DHCP "flood" Malformed Packet
Wed Mar 27, 2019 7:41 am
I'm a new user of Mikoritk.
I have notice some strange traffic coming from my hEX device.
My hEX seems to send 1 or 2 "DHCP Discover"(Malformed Packet) every second on the "lan" side.
What I have try so far:
-Reboot
-Flush my DHCP client and server config
-Disable DHCP package (the device keep sending the packets event with the package disable and after a reboot)
-Unplug every not used Ethernet port (including "Wan")
-RouterOS 6.44.1 and 6.43.1
Other strange behavior(solved):
-Some device on my network was receiving some bad DHCP config (wrong gateway, wrong netmask and wrong DNS). Those setting seems to be a mix of the DHCP config received from my ISP, my local DHCP server config and some apparently random but coherent setting.
-Fix: I have flush my DHCP-server config and reset it.
-Start of the issue: after upgrading from 6.43.1 to 6.44.1
-This issue have bring me to sniff my network traffic to try to understand what was going on, at this time, I have notice the "DHCP Discover(Malformed Packet)"
I'm lost! I try to understand what occur and how to correct it.
Thanks,
Neurotox
RouterOs: 6.44.1
Device: rb750gr3
Firmware: mt7621L 6.44.1
(I have also try with 6.43.13)
ether1: To my ISP (cable modem)
ether2: To my AP (dhcp disable on the AP)
> /system package print
Flags: X - disabled
 #   NAME        VERSION        SCHEDULED
 0   routeros-mmips        6.44.1
 1   system        6.44.1
 2 X ipv6        6.44.1
 3 X wireless        6.44.1
 4   hotspot        6.44.1
 5   mpls        6.44.1
 6   routing        6.44.1
 7 X ppp        6.44.1
 8   dhcp        6.44.1
 9   security        6.44.1
10   advanced-tools        6.44.1
> /interface print
 #     NAME                                TYPE       ACTUAL-MTU L2MTU  MAX-L2MTU MAC-ADDRESS
 0  R  ether1                              ether            1500  1596       2026 B8:69:F4:XX:XX:FB
 1  RS ether2-master                       ether            1500  1596       2026 B8:69:F4:XX:XX:FC
 2   S ether3                              ether            1500  1596       2026 B8:69:F4:XX:XX:FD
 3   S ether4                              ether            1500  1596       2026 B8:69:F4:XX:XX:FE
 4   S ether5                              ether            1500  1596       2026 B8:69:F4:XX:XX:FF
 5  R  ;;; created from master port
       bridge1                             bridge           1500  1596            B8:69:F4:XX:XX:FC
> /ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   ;;; defconf
     192.168.0.1/24     192.168.0.0     bridge1
 1   192.168.0.3/24     192.168.0.0     bridge1
 2 D xxx.xxx.xxx.154/27 xxx.xxx.xxx.128 ether1
 > /ip dhcp-server print
Flags: D - dynamic, X - disabled, I - invalid
 #    NAME                                                      INTERFACE                                                      RELAY           ADDRESS-POOL                                                      LEASE-TIME ADD-ARP
 0    dhcp1                                                     bridge1        dhcp_pool2                                                        10m
> /ip dhcp-server network print
Flags: D - dynamic
 #   ADDRESS            GATEWAY         DNS-SERVER        WINS-SERVER     DOMAIN
 0   192.168.0.0/24     192.168.0.1     192.168.0.1,8.8.8.8,xx.xxx.xxx.28,xx.xxx.xxx.29
> /ip pool print
 # NAME        RANGES
 0 dhcp_pool2        192.168.0.100-192.168.0.200
> /ip dhcp-client print detail
 0 D ;;; internet detect
     interface=ether1 add-default-route=yes default-route-distance=1 use-peer-dns=yes use-peer-ntp=yes dhcp-options=hostname,clientid status=bound address=xxx.xxx.xxx.154/27 gateway=xxx.xxx.xxx.129 dhcp-server=xxx.xxx.xxx.193
     primary-dns=xx.xxx.xxx.28 secondary-dns=xx.xxx.xxx.29 expires-after=23h3m58s
uhernandez
Re: DHCP "flood" Malformed Packet
Mon Apr 15, 2019 8:06 am
I have the same problem with an RB931 v6.44.2
With Wireshark I observe many DHCP "Malformed Packet" in my LAN, even disabling the DHCP server. What is the problem? How do I solve it?
R1CH
Forum Veteran
Forum Veteran
Mon Apr 15, 2019 11:25 pm
Disable detect-internet "feature".
EvgeniyV
Tue Apr 16, 2019 11:50 pm
Great Thanks, it helped for me.
Users browsing this forum: Google [Bot] and 47 guests
