Naweelaly
how to close all UDP ports on mikrotik?
Fri Mar 29, 2019 8:28 pm
hello guys
i need to some rules for closing all udp ports on mikrotik router. i have received an abuse from hetzner data center regarding to netscan attack through the following ports:
55341 UDP
445 TCP
53047 UDP
its so wire because previously 445 port has been closed through windows registery ( regedit rule) i am wondering how is it possible when this port is closed?
R1CH
Forum Veteran
Forum Veteran
Re: how to close all UDP ports on mikrotik?
Sat Mar 30, 2019 3:28 pm
Add rule to FORWARD chain, protocol UDP, action DROP. Note that this will break a lot of things that rely on UDP, a better solution is to fix whichever client behind your router is infected and trying to scan the internet.
AlainCasault
Trainer
Trainer
Fri Apr 05, 2019 7:45 pm
To piggy back on rich1's comment, do it for only THAT host
Shouldn't be hard to find the guilty party. If you don't know who's doing it, add a forward rule that only logs UDP outbound.
Cheers
Sent from my cell phone. Sorry for the errors.
___________________________
Alain Casault, Eng.
If I helped you, let me know!
donghoony
Fri Apr 05, 2019 9:54 pm
If you want to close all UDP ports on MikroTik, Run this command your terminal on routeros.
Replace dst-address into your destination address. I think that it isn't desirable to drop all.
/ip firewall raw add chain=prerouting dst-address=10.0.0.1 protocol=udp action=drop
Users browsing this forum: Google [Bot] and 92 guests
