geocyprus
Block DropBox with firewall
Fri Mar 29, 2019 11:10 pm
Hello to everyone ,
Can someone knows how to block traffic from dropbox , torrents , windows updates , etc ?
With Mikrotik Router firewall ?
Thank you!
R1CH
Forum Veteran
Forum Veteran
Re: Block DropBox with firewall
Sat Mar 30, 2019 3:37 pm
As it's HTTPS you need to block via DNS or IP range, not recommended. If bandwidth consumption is a concern then use queues or data limits for your users.
AlainCasault
Trainer
Trainer
Fri Apr 05, 2019 7:42 pm
Try the tls-host field in a mangle rule. It works for me blocking other sites like Netflix.
And you can use the same marking in simple queues to rate limit.
Cheers,
Sent from my cell phone. Sorry for the errors.
___________________________
Alain Casault, Eng.
If I helped you, let me know!
Users browsing this forum: No registered users and 58 guests
