shiyiqiang08
ros rb4011 2.4g can't be connected by 4 devices?
Sun Mar 31, 2019 11:56 am
i use my rb4011
but when the 2.4 wireless devices over 4
i cant't connect it any more
why
anav
Re: ros rb4011 2.4g can't be connected by 4 devices?
Sun Mar 31, 2019 4:37 pm
Obviously you need the RB5011. :-)
Wait, let me check my crystal ball............ Its cloudy today can't see much.
I know, my tarot cards are handy........... drats there is cat puke on them, useless.
Hmm I know, post your config
/export hide-sensitive file=yourconfig31mar
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
shiyiqiang08
Mon Apr 01, 2019 2:15 pm
Thank you very much. My configuration is to configure 20 virtual aps. When I connect to more than four devices, each device connects to a wireless connection, and the latter device can not be connected.
R1CH
Forum Veteran
Forum Veteran
Mon Apr 01, 2019 2:33 pm
With 20 virtual APs you are probably destroying the channel with beacons. Make sure to set g/n only or change your data rates.
https://r1ch.net/blog/wifi-beacon-pollution
anav
Mon Apr 01, 2019 6:21 pm
One should realize that stating
i use my rb4011
why?
Is NOT the same situation as I have created 20 virtual WLANS and am having issues with this setup when connecting more than four devices to (a single vLWAN or four different vLWANs etc.)
Draw a diagram as to the network setup and then there will be less confusion! :-)
shiyiqiang08
Wed Apr 03, 2019 6:57 am
i use my rb4011
why?
thank you very much
There is something wrong with my description
I have restored the device, so the configuration is gone, but your description is clear
shiyiqiang08
Wed Apr 03, 2019 7:00 am
i use my rb4011
why?
Users browsing this forum: Bing [Bot] and 47 guests
