vasilevkirill
Trainer
Trainer
[Feature request] Address List extension
Sat Apr 06, 2019 1:37 am
I would be interested to see such functionality in the address lists.
Code: Select all
/ip firewall address-list add list=hosts address=192.168.0.0/16 wildcard=255.255.10-20.255
Only networks will be third octet is in the range of 10-20
Code: Select all
/ip firewall address-list add list=hosts address=192.168.0.0/16 wildcard=255.255.0.10
third octet 0-255 and fourth octet 10
Code: Select all
/ip firewall address-list add list=hosts address=192.168.0.0/16 wildcard=255.255.255.10,15,20,30-35
fourth octet 10 or 15 or 20 or in range 30-35
Code: Select all
/ip firewall address-list add list=GOOGLE address=AS15169
Dynamic address list, address from AS number
Code: Select all
[admin@MT-AP-KIRILL-ROOM] /ip firewall address-list> pr
Flags: X - disabled, D - dynamic
# LIST ADDRESS CREATION-TIME TIMEOUT
0 GOOGLE AS15169 apr/06/2019 01:07:35
1 D ;;; AS15169
GOOGLE 103.21.184.0/22 apr/06/2019 01:27:57
2 D ;;; AS15169
GOOGLE 103.227.68.0/22 apr/06/2019 01:27:57
3 D ;;; AS15169
GOOGLE 103.240.192.0/22 apr/06/2019 01:27:57
Code: Select all
/ip firewall address-list add list=mysite.com address=*.mysite.com
wildcard or asterisk in all sub domain.
I know that you cannot get a list of sub domains, but if the router is a DNS server, it can find all such domains that are in the cache.
Vasilev Kirill
( MTCNA, MTCRE, MTCWE, MTCTCE, MTCUME, MTCINE, MTCIPv6E, MTCSE )
MikroTik Certified Trainer & Consultant
Trainer Сertificate Number TR0417
https://www.mikrotik.me
Cell:+7 (905) 207-35-78
Jotne
Re: [Feature request] Address List extension
Sat Apr 06, 2019 7:23 pm
I would like a command that list all the address list and if possible the number of entries in them.
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
neutronlaser
Sun Apr 07, 2019 3:18 am
How could we use this:
whois -h whois.radb.net -- '-i origin AS15169' | grep ^route
Which gets every IP address range Google uses
Into a Mikrotik address list?
nostromog
Sun Apr 07, 2019 10:57 am
EDIT: Change sort to sort -u so that no full duplicates remain.
Those two give separate raw prefix lists, one for IPv4 and another for IPv6:
whois -h whois.radb.net -- '-i origin AS15169' | grep ^route: | awk '{print $2}'
whois -h whois.radb.net -- '-i origin AS15169' | grep ^route6: | awk '{print $2}'
Splitting into ipv4 and ipv6 is needed due to the strange way RouterOS deals with IPv6.
Now this will turn them into .rsc files ready to import:
(echo "/ip firewall address-list {"; for prefix in $(whois -h whois.radb.net -- '-i origin AS15169' | grep ^route: | awk '{print $2}'| sort -u); do echo "add list=goog address=$prefix timeout=1d"; done; echo "}") > goog4.rsc
(echo "/ipv6 firewall address-list {"; for prefix in $(whois -h whois.radb.net -- '-i origin AS15169' | grep ^route6: | awk '{print $2}'| sort -u); do echo "add list=goog address=$prefix timeout=1d"; done; echo "}") >goog6.rsc
$ ls -l goog*
-rw-r--r-- 1 user user  345227 apr  7 08:25 goog4.rsc
-rw-r--r-- 1 user user   11439 apr  7 08:24 goog6.rsc
$ wc -l goog*.rsc
  7146 goog4.rsc
   225 goog6.rsc
  7371 total
$ scp goog6.rsc 192.168.88.1:
$ ssh 192.168.88.1 "/import goog6.rsc"
$ ssh 192.168.88.1 "/ipv6 firewall address-list print where list=goog"
 #   LIST                 ADDRESS
 0 D goo                  2001:1900:2292::/48
 1 D goo                  2001:4860::/32
 2 D goo                  2401:fa00::/32
 3 D goo                  2401:fa00::/42
 4 D goo                  2401:fa00:4::/48
 5 D goo                  2404:6800::/32
 6 D goo                  2404:6800:4001::/48
Note that I only tested the ipv6 one, it is way smaller. Also, I put a timeout so that the lists will go on RAM.
Note also that the IPv6 list will need deduplication. It contains separate sub-prefixes of a given prefix as can be seen in my example. For instance it contains 2401:fa00::/32, 2401:fa00::/42 and 2401:fa00:4::/48, all included in the first.
neutronlaser
Sun Apr 07, 2019 7:10 pm
That's awesome. It is a good start to making a script that could for example let Google or Facebook in a Walled Garden list or perhaps QoS rule or blocking. I wish I knew how to deduplicate it.
It would be great as an online script generator. I tested it and it seemed an effective way to block Facebook in my firewall.
nostromog
Mon Apr 08, 2019 12:27 pm
When I tried ipv4 it was failing due to a duplicate, but changing sort -> sort -u makes it load. I edited the post. Removing entries that fall "inside"other entries, though, is a non-trivial programming problem.
neutronlaser
Mon Apr 08, 2019 2:34 pm
That's awesome. The extra efficiency of deduplication of overlapping ranges isn't important enough in my case.
Here is how to export Facebook to a single address list:
(echo "/ip firewall address-list {"; for prefix in $(whois -h whois.radb.net -- '-i origin AS63293' | grep ^route: | awk '{print $2}'| sort -u); do echo "add list=facebook address=$prefix timeout=1d"; done; echo "}") > facebook.rsc
(echo "/ip firewall address-list {"; for prefix in $(whois -h whois.radb.net -- '-i origin AS54115' | grep ^route: | awk '{print $2}'| sort -u); do echo "add list=facebook address=$prefix timeout=1d"; done; echo "}") > facebook.rsc
(echo "/ip firewall address-list {"; for prefix in $(whois -h whois.radb.net -- '-i origin AS32934' | grep ^route: | awk '{print $2}'| sort -u); do echo "add list=facebook address=$prefix timeout=1d"; done; echo "}") > facebook.rsc
msatter
Mon Apr 08, 2019 2:43 pm
If you look on bgp.he.net then you see for Facebook huge IPv6 ranges that they own and so easily block-able:
2a03:2880::/32
2a03:2887:ff34::/48
2401:db00::/32
2620:0:1c00::/40
2803:6080::/32
https://bgp.he.net/search?search%5Bsear ... mit=Search
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46Beta59 / Winbox 3.20 / MikroTik APP 1.3.7
Having an Android device, use https://github.com/M66B/NetGuard/releases (no root required)
neutronlaser
Mon Apr 08, 2019 2:54 pm
I don't use IPv6 but great information for those who do.
Simono
Tue Apr 09, 2019 1:48 pm
Now I don't have Linux (HDD failure). How do this on router or Windows PC?
Sent from my phone by Tapatalk
neutronlaser
Tue Apr 09, 2019 2:03 pm
Cygwin with package for whois (not sure which one it is in, maybe bindutils)
Simono
Tue Apr 09, 2019 2:17 pm
Thanks, I will try
Users browsing this forum: No registered users and 95 guests
