MUM Europe 2020
OldsMan
RB3011 reboot itself - kernel panic
Sat Apr 06, 2019 9:44 am
I have IPSEC tunnel from Mikrotik devices to a Checkpoint site . The connection was working fine, but after an update (unfortunatelly I don't remember what version) on the Mikrotiks when I allowing traffic thru this specific tunnel the RB3011 devices rebooted itself, after the boot i see kernel panic in the log
I have 3 rb3011 with same problem, but working well with RB850Gx2
The tunnel came up, but as soon as traffic from Mikrotik side start to flow to the Checkpoint site it crash
If the traffic is disabled from the Mikrotik site the device is staying up.
Any ideas ?
Thanks ;)
vecernik87
Long time Member
Long time Member
Re: RB3011 reboot itself - kernel panic
Mon Apr 08, 2019 10:21 pm
The only idea anyone should mention is advice to contact support@mikrotik.com and send them your autosupout.rif
I am pretty sure it has something to do with recently enabled HW support for IPsec on rb3011 but only support staff can inspect your autosupout, confirm the bug and fix it in upcoming software updates. That way, not only you will get fix but also everyone else who suffer from the same condition.
OldsMan
Mon Apr 08, 2019 10:36 pm
Thanks, I already did this.
Users browsing this forum: MSN [Bot] and 76 guests
