ds12345
Hotspot https redirect feature
Tue Apr 09, 2019 6:44 pm
Hi
In 6.44 Mikrotik implemented below:
hotspot - added "https-redirect" under server profiles;
I've tested this and it doesnt seem to work, not as far as I can tell. I can see it adding into the firewall rules
8 D chain=hs-unauth action=redirect to-ports=64875 protocol=tcp in-interface=ether2-inside dst-port=443
The rule gets hit when I go to google or something as unlogged in, but nothing happens, no redirects.
Is this tested by anyone, does it work?
wallpaper
Re: Hotspot https redirect feature
Wed Apr 10, 2019 10:48 am
Anyone? Been quite a few large topics on this previously. Is it working for anyone?
Sob
Wed Apr 10, 2019 5:39 pm
I don't use hotspot, but doesn't it do what it should, as described in manual?
Whether to redirect unauthenticated user to hotspot login page, if he is visiting a https:// url. Since certificate domain name will mismatch, often this leads to errors, so you can set this parameter to "no" and all https requests will simply be rejected and user will have to visit a http page.
Or in other words, from someone else who tested it:
https-redirect=yes
if unlogged user try to open https website, it will be redirected to hostpot login with https. same behavior as previous version
so browser will show cert warning because cert common name is not same with domain
https-redirect=no
if unlogged user try to open https website, it will be rejected/refused so browser will error like there is no internet access
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
ds12345
Sun Apr 14, 2019 1:09 pm
No,
https-redirect=yes
This part doesn't work. Basically it just does the below:
https-redirect=no
Anyone else managed to test? I can see the firewall rule getting hit, but nothing happens.
R1CH
Forum Veteran
Forum Veteran
Mon Apr 15, 2019 11:37 pm
The redirection will never work due to security guarantee of HTTPS. Documentation should be like this:
https-redirect=yes
Show a security error if user tries to open HTTPS website.
https-redirect=no
Show a network error if user tries to open HTTPS website.
Users browsing this forum: Onlineallthetime and 39 guests
