angboontiong
PWR-LINE adapter speed is ?
Tue Apr 09, 2019 6:44 pm
normis
Re: PWR-LINE adapter speed is ?
Wed Apr 10, 2019 9:10 am
100Mbit
mkx
Wed Apr 10, 2019 12:00 pm
HomePlug AV standard, to which conforms QCA6410 chip (supposedly used by PWR-LINE adapters), states around 80Mbps throughput on MAC layer. Possibly that's half-duplex speed, so in reality one will get slightly less even in perfect power-wire conditions.
BR,
Metod
angboontiong
Wed Apr 10, 2019 12:29 pm
100Mbit
Can it use for 3 phase power Cabling house?
Means cross phase..
anav
Wed Apr 10, 2019 3:40 pm
Avoid this product. The chip was put out in 2012 and performs terribly. Much better for electrical wiring is products based on the 2014 qualcom QCA7450 and the better still 2015 QCA7500 chip.
But wait, they dont have a USB attached. Someone has got you by the short and curlys................. I am personally waiting for the "new" MT Bmax with usb cord attached and poe powered, yes even better than the latest technology, don't rely on a computer chip thats so new school....... instead the 1975Max with USB is your answer to replaying movies.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
littlebill
Wed Apr 10, 2019 5:40 pm
i own them. the BEST speed you will see is 70mbit.
really would like winbox to show the link speed of the powerline, it only currently shows via a cli command
mkx
Wed Apr 10, 2019 9:11 pm
100Mbit
Means cross phase..
You can, but max speed will be less than when used on same phase.
BR,
Metod
anav
Wed Apr 10, 2019 9:26 pm
The newer chips and firmware with the QCA7500 work way better across circuits. (by newer I mean circa 2014/2015) as opposed to the one in the MT circa 2012. Of note no new chips for powerline have come out since the QCA7500.
sindy
Sat Apr 13, 2019 6:37 pm
I've seen a statement somewhere that the RF signal used to carry the Ethernet data has to be connected to the neutral wire because it is common to circuits using any of the three phases. So if you can observe a difference in throughput on the same socket-to-socket distance (electrical, of course) depending on whether the sockets are on the same phase or on different ones, it may be worth it to turn the plugs 180 degrees and try again. I don't know your country - in some countries the position of phase and neutral in the socket is standardized and you can insert a plug with protective earth contact to the socket two ways, in others there is only one way to insert the plug and the position of the phase and neutral may be different than the one used in a multi-marked HomePlug product.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
frogale
Sun Oct 06, 2019 11:53 am
When two devices (PWR-LINE AP) is on the same power socket they go up to 94 Mbit TCP (one connection).. From my flat to hallway socket (around 20 metres of power wiring and through circuit-braker (same phase) it is around 53 Mbits stable.. 3-5ms.. It is usable..
normis
Mon Oct 07, 2019 9:14 am
We also have PWR LINE PRO with gigabit chipset
odin123
Fri Apr 24, 2020 4:08 pm
I just got PL7510Gi which is rated for 600mbit with 1gbe interface . I did test it and I can only get 142mbit and this is in 2 different rooms next to each other.
I am not sure if or how I can get better speeds that that. If anybody can advise it would be much appreciated. Also to add, there are no power extensions or any other
elements before the power line adaptors, they are directly plugged in to the wall sockets.
Regards
G.
Users browsing this forum: BlackRat, Google [Bot], oskarsk and 106 guests
