MUM Europe 2020
eastonhe
RouterOS 6.44.x pppoe client issue
Thu Apr 11, 2019 5:25 pm
last working verson:
6.43.12
I have serval device both have the same issue:rb750gr3 rb450gx4 x86
After update RouterOS to 6.44,pppoe client is having a tx drops issue,it happends every 1 minute and drops 2 packets regulary.
When I down grade to 6.43.12 everything is ok and no tx drop issues.
So I'm wondering what is wrong with my router? Config issue or RouterOS issue?
alexmatv325
Re: RouterOS 6.44.x pppoe client issue
Mon Apr 15, 2019 2:08 pm
Same Here on L2TP Connection.
dsliesrn
Tue Apr 30, 2019 5:00 pm
Same problem
CoMMyz
Wed May 01, 2019 3:19 am
There is also a problem with the 6.44.x branch with Radius and PPPoE - radius timing out after a few days of operation.
This has been reported to Mikrotik with support file via email.
sysnotdown
Wed May 01, 2019 11:05 am
also have problem on 5G wifi. it break connection for a short time especially on first connection!
inteq
Wed May 01, 2019 11:18 am
Using PPPoE client at home with ROS 6.44.3.
Haven't seen any packet loss.
Muzaki
Mon May 20, 2019 10:55 am
I had the same problem, but it seems like the problem is on CCR (tile) and not on RB100AH (powerpc)
When a client tries to authenticate, it gets a timeout. Restart solved the problem (somethimes), But then userman didnt respond for a few minutes.
Downgraded CCR's and everything is normal again.
Muzaki
Tue Jun 04, 2019 11:50 am
After a few days, the same problem occures on PowerPC too
ahmad201020
Fri Jul 05, 2019 10:18 pm
set discover-interface-list=none
dropped packet is discovery packet
dhakabappy
Sun Dec 29, 2019 3:57 pm
Solution is
set discover-interface-list= !dynamic
if discovery on a dynamic interface then
every pppoe interface may have Tx Drop
Users browsing this forum: AUsquirrel, Bing [Bot], tdw and 100 guests
