sterod
Android Mobile App Feature Request
Tue Apr 16, 2019 3:34 pm
There does not appear to be a dedicated forum for the mobile app, so I did not know where else to post this.
Can you please add the option to sort the list of Saved devices by their Note
I have over a hundred devices in this list and without sorting its very difficult to find a particular host. I realize the search magnifying glass button is there, but I would prefer an ordered list to begin with.
Thank You
Jivo
Re: Android Mobile App Feature Request
Fri Apr 19, 2019 11:52 pm
Could you please introduce the possibility do delete all saved connections?
I have hundreds of them, and need to reload them from time to time from my other machine. In order not to duplicate, I have to be able to delete existing list.
At this moment, the only workaround I am aware of for cleaning the existing set of settings is to uninstall and reinstall the app.
msatter
Sat Apr 20, 2019 12:42 pm
There is only one official thread on that and it can be found here:
viewtopic.php?f=21&t=98407
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46Beta / Winbox 3.20 / MikroTik APP 1.3.4
Having an Android device, use https://github.com/M66B/NetGuard/releases (no root required)
Users browsing this forum: MSN [Bot] and 82 guests
