moorenproductief
Make external IP address accessible on secondary port
Thu Apr 18, 2019 12:16 pm
I want to put two mikrotik routers in a chain. My ISP provides me an ip block and I need that each router has his OWN EXTERNAL IP. The reason that I want to chain the routers is that I need to control and monitor the bandwidth of the secondary router. Is such a thing possible on routerOS? And if yes... How? I have been googeling and experimenting for quit some time now. Thanks for any response!
I added a diagram so my situation becomes more clear.
Marco
McSee
Re: Make external IP address accessible on secondary port
Thu Apr 18, 2019 5:00 pm
I can't verify myself if it works this way but you may want to try -
on first mikrotik
- set up "bandwidth controlled port" as a separate interface
- then execute "/ip address add address=xx.xx.xx.98/32 interface="bandwidth controlled port" network=xx.xx.xx.99"
on the second
- set up xx.xx.xx.99/29 address
- add default route using xx.xx.xx.98 as a gateway
Sob
Thu Apr 18, 2019 10:09 pm
^^^^ This works, but:
1) Use the same /32 addressing on second router too, only with swapped addresses. Because the whole /29 won't be available at that port.
2) You also need on first router:
/ip arp
add address=xx.xx.xx.99 interface=<WAN> published=yes
3) Make sure that you will allow forwarding to/from xx.xx.xx.99 on first router.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
gotsprings
Forum Veteran
Forum Veteran
Fri Apr 19, 2019 2:51 pm
Put a dumb switch infront of the two Mikrotiks. $30 or less.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
Sob
Fri Apr 19, 2019 5:43 pm
Dumb switch and both routers being independent won't go well with the requirement to control other router's bandwidth (on first router, as I undertand it).
gotsprings
Forum Veteran
Forum Veteran
Fri Apr 19, 2019 10:19 pm
Which should be done per router.
But let's face it... This could / should all be done on one router.
Mark Twain
excession
Sun Apr 21, 2019 2:14 am
You could bridge two ports together and feed your WAN into one of these. Then set one of your external IPs on this bridge, plug your next router into the other port and set another of your external IPs on that routers interface.
You can then enable the IP firewall in Bridge Settings on the first router which will allow you to use simple queues on this router to shape traffic on the next router. I think this setup is called something like transparent traffic shaping in the wiki if you want to search for it.
Finally setup a simple queue to shape the traffic of the next router by targeting it’s external IP.
moorenproductief
Thu May 30, 2019 3:56 pm
Thank you all for relying! For some reason I dit not receive any updates on this post by email so I was thinking there were no replies at all.
Next week I'm gonna try all suggestions and will reply which one works best for me.
anav
Thu May 30, 2019 4:30 pm
I'm with got springs on this one. Could and should be done on one router. Anything else is overly complex.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
Users browsing this forum: MSN [Bot] and 64 guests
