Andrewk2
CCR1072 vs Oem İ9-9900K
Mon Apr 29, 2019 7:26 pm
Where can I get the best processor performance? I have 10g uplink with high CPU usage.
Or is there anything you'd suggest better?
Regards.
Andrewk2
Re: CCR1072 vs Oem İ9-9900K
Wed May 01, 2019 10:01 am
I will use it for a firewall. Which is more efficient?
inteq
Wed May 01, 2019 10:36 pm
Efficient for me means best buck for best performance&features/watt.
If this means the same to you, get the Mikrotik.
For just routing and NAT, an i3 can handle 10 Gbps with lots of room to spare. An i9 9900k is just for show and to heat the room during winter.
lambert
Long time Member
Long time Member
Wed May 01, 2019 10:46 pm
If doing BGP, before RouterOS 7, you want an X86 box. It doesn't have to be top of the line.
The x86 boxes will run circles around the CCR for single threaded tasks. The CCR will be fine for tasks that can be split across multiple cores.
Elliot
Thu May 02, 2019 12:34 pm
Regards.
It really depends on your needs. Mikrotik CCR1072 is great with anything that have a lot of smaller connections.
Tobei
Thu May 02, 2019 2:26 pm
we are using the CCR1072 and the CCR1036 (the last one is available with two SFP+ interfaces) as Firewall and for NAT. If you need more than two SFP+ interfaces, take the 1072, if you are fine with two, think about the CCR1036.
The performance in our case is more than enough even if we push ~6-7GBit through the firewall, the CCR is just idling. We are using statefull firewall rules + FastPath/FastTrack so a lot of computation is done in hardware. If you have a lot of IPv6 traffic the CPU load will be higher, because FastPath/FastTrack works a the moment only with IPv4 traffic.
Regards Tobias
Andrewk2
Sun May 05, 2019 2:13 pm
Regards.
Regards Tobias
Thank you everyone. We use it for game firewall. Does the CCR1072 or Oem 9900K processor work better?
Tobei
Sun May 05, 2019 2:52 pm
I let iperf run between different subnets, so the CCR1072 is doing firewall and routing: >9GBit For our needs the CCR1072 is perfect, fast and also a low power consumption. Can you specify how many traffic you expect and which protocol you are planning to use (udp/tcp)?
Regards Tobias
kos
Tue May 07, 2019 3:55 pm
Andrewk2
Thu May 30, 2019 11:06 pm
I'm putting oem up. What do you recommend to me motherboard?
Intel® Core™ i9-9900K Processor
Intel X520-DA2 Ethernet Card
Azma
Fri May 31, 2019 9:55 am
i prefer CCR1036-8G-2S+ for routing purpose and use another routerboard (or maybe existing) for firewall.
edwinlai33
Fri May 31, 2019 11:01 am
prefer I9-9900k, but there is some issue in "display cpu usage" , performance is perfect
viewtopic.php?f=2&t=141611
Andrewk2
Mon Jun 03, 2019 10:43 pm
What are you using for? What do you use motherboard and ethernet card?
edwinlai33
Tue Jun 04, 2019 8:17 am
edge router, supermicro C9X299-PGF and intel 520
Users browsing this forum: pe1chl, sindy, ThrowAway and 91 guests
