MUM Europe 2020
peinamuertos
Two EOIP tunnels and traffic problem
Fri May 10, 2019 12:20 am
Hi there,
I set up two EOIP tunnels using one bridge for both. Different users, different IPs... everything works fine... separately. If I turn on both tunnels, the traffic only is transmitted from the second one. The first one has no outgoing traffic. What am I doing wrong?
Attached You can find a simple draw of my connections schema. And sorry for my basic english!
Cheers
Rubén
sindy
Re: Two EOIP tunnels and traffic problem
Fri May 10, 2019 9:58 am
It should work fine but the information on the drawing is insufficient to suggest what might be wrong, so post the configuration of all three machines following the hint in my automatic signature and the output of /interface eoip print detail, /interface bridge print detail, and /interface bridge host print when both tunnels are up.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
peinamuertos
Fri May 10, 2019 10:45 am
Hi again,
Thanks for your help.
PPTP Server config
# may/10/2019 08:10:11 by RouterOS 6.44.3
# software id = CTWP-R4CL
# model = RouterBOARD 941-2nD
# serial number = 8CE5081EF3C1
add admin-mac=CC:2D:E0:64:D3:89 auto-mac=no comment=defconf igmp-snooping=yes \
name=bridge
set [ find default-name=ether1 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether2 ] advertise=\
set [ find default-name=ether3 ] advertise=\
set [ find default-name=ether4 ] advertise=\
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-YARARA \
wireless-protocol=802.11
/interface eoip
add local-address=192.168.88.200 mac-address=02:42:62:50:21:C8 name=\
eoip-tunnel1 remote-address=192.168.88.201 tunnel-id=0
add !keepalive local-address=192.168.88.240 mac-address=02:1E:1F:F9:7F:53 name=\
eoip-tunnel2 remote-address=192.168.88.241 tunnel-id=666
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=******* \
wpa2-pre-shared-key=*******
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=PPTP-Pool ranges=192.168.1.125-192.168.1.150
add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge interface=ether1
add bridge=bridge interface=eoip-tunnel1
add bridge=bridge interface=eoip-tunnel2
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=wlan1 list=LAN
/interface pptp-server server
set authentication=chap,mschap1,mschap2 enabled=yes
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
192.168.88.0
add address=192.168.1.4/24 interface=ether2 network=192.168.1.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
set allow-remote-requests=yes servers=80.58.61.250,80.58.61.254
/ip dns static
add address=192.168.1.4 name=router.lan
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=established,related disabled=yes
established,related,untracked
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=VPN passthrough=yes \
src-address=192.168.88.2-192.168.88.254
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
add distance=1 gateway=192.168.1.1
add disabled=yes distance=1 dst-address=239.0.2.0/32 gateway=bridge
/ppp secret
add local-address=192.168.88.210 name=username1 password=***** \
remote-address=192.168.88.211 service=pptp
add local-address=192.168.88.200 name=eoipuser1 password=******** remote-address=\
192.168.88.201 service=pptp
add local-address=192.168.88.240 name=eoipuser2 password=******** remote-address=\
192.168.88.241 service=pptp
EOIP Tunnel Client 1
# may/10/2019 09:19:04 by RouterOS 6.44.3
# software id = TRE9-T0ST
# serial number = 8CE508EEA453
add admin-mac=CC:2D:E0:64:96:9F auto-mac=no comment=defconf igmp-snooping=yes name=bridge
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether3 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether4 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
/interface pptp-client
add connect-to=pptp.server.address disabled=no keepalive-timeout=disabled name=pptp-out1 password=****** user=eoipuser1
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=2 band=2ghz-b/g/n channel-width=20/40mhz-Ce country=spain disabled=no distance=indoors frequency=auto frequency-mode=regulatory-domain mode=ap-bridge ssid=MikroTik-SS \
/interface eoip
add !keepalive local-address=192.168.88.201 mac-address=02:38:92:53:EE:25 name=eoip-tunnel1 remote-address=192.168.88.200 tunnel-id=0
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=PcEERGbn wpa2-pre-shared-key=*******
add name=dhcp ranges=192.168.66.10-192.168.66.254
add address=192.168.66.1/24 comment=defconf interface=ether2 network=192.168.66.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.66.0/24 comment=defconf gateway=192.168.66.1 netmask=24
/ip dns static
add address=192.168.66.1 name=router.lan
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related disabled=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add disabled=yes distance=1 gateway=192.168.0.1
add distance=1 dst-address=172.26.22.0/32 gateway=pptp-out1
add distance=1 dst-address=172.26.23.0/32 gateway=pptp-out1
add distance=1 dst-address=239.0.2.0/32 gateway=eoip-tunnel1
/ppp secret
add name=userppp password=********
EOIP Client 2
# may/10/2019 09:23:06 by RouterOS 6.44.3
# software id = DGM8-J1KA
# model = RB941-2nD
# serial number = 93710A80B802
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full mac-address=CC:2D:E0:64:96:9E
set [ find default-name=ether2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full mac-address=CC:2D:E0:64:96:9F
set [ find default-name=ether3 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full mac-address=CC:2D:E0:64:96:A0
set [ find default-name=ether4 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full mac-address=CC:2D:E0:64:96:A1
/interface wirelessN
set [ find default-name=wlan1 ] name=wlan2 ssid=MikroTik
/interface eoip
add !keepalive local-address=192.168.88.241 mac-address=02:38:92:53:EE:25 name=eoiptunnel1 remote-address=192.168.88.240 tunnel-id=666
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=***** wpa2-pre-shared-key=*******
add name=dhcp ranges=192.168.77.10-192.168.77.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add connect-to=pptp.server.address disabled=no keepalive-timeout=disabled name=PPTP-client1 password=******* profile=default user=eoipuser2
add bridge=bridge interface=eoiptunnel1
add bridge=bridge comment=defconf disabled=yes interface=LAN
add interface=wlan2 list=WAN
add address=192.168.77.1/24 comment=defconf interface=ether1 network=192.168.77.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=wlan2
add address=192.168.77.0/24 comment=defconf gateway=192.168.77.1 netmask=24
/ip dns static
add address=192.168.77.1 name=router.lan
add distance=1 dst-address=172.26.22.0/32 gateway=PPTP-client1
add distance=1 dst-address=172.26.23.0/32 gateway=PPTP-client1
add distance=1 dst-address=239.0.2.0/32 gateway=eoiptunnel1
Interface configs
[admin@MikroTik] /interface eoip>> /interface eoip print detail
0 R name="eoip-tunnel1" mtu=auto actual-mtu=1408 l2mtu=65535 mac-address=02:42:62:50:21:C8 arp=enabled arp-timeout=auto loop-protect=default loop-protect-status=off loop-protect-send-interval=5s
loop-protect-disable-time=5m local-address=192.168.88.200 remote-address=192.168.88.201 tunnel-id=0 keepalive=10s,10 dscp=inherit clamp-tcp-mss=yes dont-fragment=no allow-fast-path=yes
1 R name="eoip-tunnel2" mtu=auto actual-mtu=1408 l2mtu=65535 mac-address=02:1E:1F:F9:7F:53 arp=enabled arp-timeout=auto loop-protect=default loop-protect-status=off loop-protect-send-interval=5s
loop-protect-disable-time=5m local-address=192.168.88.240 remote-address=192.168.88.241 tunnel-id=666 dscp=inherit clamp-tcp-mss=yes dont-fragment=no allow-fast-path=yes
[admin@MikroTik] > /interface bridge print detail
0 R ;;; defconf
name="bridge" mtu=auto actual-mtu=1408 l2mtu=1598 arp=enabled arp-timeout=auto mac-address=CC:2D:E0:64:D3:89 protocol-mode=rstp fast-forward=yes igmp-snooping=yes multicast-router=temporary-query
multicast-querier=no startup-query-count=2 last-member-query-count=2 last-member-interval=1s membership-interval=4m20s querier-interval=4m15s query-interval=2m5s query-response-interval=10s
startup-query-interval=31s250ms igmp-version=2 auto-mac=no admin-mac=CC:2D:E0:64:D3:89 ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6 vlan-filtering=no
dhcp-snooping=no
admin@MikroTik] > /interface bridge host print
Flags: X - disabled, I - invalid, D - dynamic, L - local, E - external
# MAC-ADDRESS VID ON-INTERFACE BRIDGE AGE
0 D 00:26:86:00:00:00 ether1 bridge 6s
1 DL 02:1E:1F:F9:7F:53 eoip-tunnel2 bridge
2 D 02:38:92:53:EE:25 eoip-tunnel2 bridge 1s
3 DL 02:42:62:50:21:C8 eoip-tunnel1 bridge
4 D 2C:CC:44:34:B2:C9 ether1 bridge 6s
5 D 34:57:60:DB:35:A3 ether1 bridge 0s
6 D 3C:5C:C4:07:5A:43 ether1 bridge 6s
7 D 68:63:59:95:FF:DB ether1 bridge 27s
8 D 68:9A:87:54:56:90 ether1 bridge 6s
9 D 90:EF:68:3C:A9:67 eoip-tunnel2 bridge 3s
10 D AA:AA:AA:1B:45:C7 ether1 bridge 0s
11 D AA:AA:AA:1B:46:C7 ether1 bridge 0s
12 D BC:60:A7:DC:37:35 ether1 bridge 6s
13 D C4:95:00:AC:D5:BF ether1 bridge 6s
14 D CC:2D:E0:64:96:9F eoip-tunnel2 bridge 24s
15 DL CC:2D:E0:64:D3:88 ether1 bridge
16 DL CC:2D:E0:64:D3:89 bridge bridge
Again, thanks for your support
peinamuertos
Fri May 10, 2019 10:47 am
And sorry, I realized that IPs of my drawing are not correct. They are all in 192.168.88.x subnet.
Regards
sindy
Fri May 10, 2019 11:30 am
Could it be that both the PPTP clients are connected from behind the same public IP address? One of the problems with PPTP is that it uses GRE, and one of the problems with GRE is that it doesn't use the concept of ports so only a single GRE "session" can exist between two IP addresses, so if one of these two addresses belongs to a NAT device and there is more than one GRE endpoint behind it, only one of the GRE sessions works at a time. Some NATs let the private->public packets run for both sessions which might explain why the EoIP tunnels are both reported as up at the "PPTP server" machine.
peinamuertos
Fri May 10, 2019 12:56 pm
Yes, both eoiptunnels are connected trought the same public IP address to PPTP Mikrotik server... so, what can I do? Is there any way to avoid using another public IP? Maybe using another tunnel type?
Thanks!
sindy
Fri May 10, 2019 1:25 pm
PPTP is a security hole anyway, so use plain IKEv2 (L2TP encrypted using IPsec suffers from the same issue of multiple clients behind a NAT, even though the detailed reason is slightly different, and without encryption it is totally insecure).
peinamuertos
Fri May 10, 2019 2:57 pm
I know, but first I'd like to solve the main issue. So, no ideas for tunneling using same public internet IP?
Sorry, as you can see I'm a little newbie...
sindy
Fri May 10, 2019 3:22 pm
The problem are not the EoIP tunnels themselves - they are just victims of the PPTP problem with NAT. So until you set up a VPN which a) does not use TCP as transport and b) does not have problems with two clients behind the same public IP, the EoIP won't work at both sites simultanously. And requirements a) and b) narrow the list to just two types of VPN out of those available on Mikrotik: L2TP without IPsec (so no encryption at all) and IKEv2.
peinamuertos
Fri May 10, 2019 9:22 pm
Well, I tried BCP bridging with l2tp interface and... the same issue. I don't know why the behaviour is just the same. As you can see, there's no EoIP tunneling and connections (separately) runs so fine. I'm just thinking that I'm missing something...
When both connections are running, one of them sends no packets
sindy
Fri May 10, 2019 9:37 pm
Have you set use-ipsec to yes and ipsec-secret in l2tp configuration?
sindy
Fri May 10, 2019 10:52 pm
Btw, there is one more issue in your configuration, but I don't think it explains the L2 tunnel behaviour. On the server, you have attached the /ip dhcp-client to ether1 and attached two /ip address to ether2 but at the same time you've made ether1 and ether2 member ports of /interface bridge named bridge. That's incorrect, elements of IP configuration cannot be attached to interfaces which are at the same time member ports of bridges, it causes weird errors. So you fix change this first of all.
Next, can you re-confirm again that your physical network topology looks like this?
ascii art code
        ______________
                                   ____                    ______________        |              |
 ____________                     (    )                  |              |-------| VPN client 1 |
|            | public IP A       (      )     public IP B |              |       |______________|
| VPN server |------------------(        )----------------| WAN(NAT) LAN |        ______________
|____________|                   (______)                 |              |       |              |
                                                          |______________|-------| VPN client 2 |
        |______________|
If so, the L2TP tunnels can only work for both clients if ipsec=yes is not used in the l2tp configuration.
McSee
Sat May 11, 2019 3:53 am
peinamuertos,
do you really have the same MAC address on both clients' bridges ?
sindy
Sat May 11, 2019 8:48 am
Worse than that, have you saved a backup on client 1 and loaded it on client 2? Because it's not only the admin-mac of the bridge, it's also that the MAC addresses of Ethernet ports are user-configured on client 2.
For bridging of external traffic this doesn't matter, but if you check the tunnel by sending data to the IP address of the bridge on the client device, the duplicity does matter.
And loading a backup of one device to another is prohibited in general, you have to export the configuration on one device and import it on the other one after editing out the duplicities from the script file. In your case, reset client 2 to defaults, export configuration from client 1 and import it to client 2 after making the necessary changes in it.
peinamuertos
Sat May 11, 2019 1:15 pm
Well,.. sorry. I told you... Newbie. Changed config and new MAC = all working under L2TP with IPsec
Thanks a lot to everyone!!!
Users browsing this forum: AzizHalal, saibarker and 104 guests
