sleerf
Weird issue. 3011 does what ccr won't
Sun May 12, 2019 3:47 am
Weird issue. 3011 passes static external and internal ips just fine using two ports plugged into the same switch. But a CCR I can't get it to do it. I thought the CCR was bad. Bought a new one (ccr 1009). It won't do it either. Any ideas?
sindy
Re: Weird issue. 3011 does what ccr won't
Sun May 12, 2019 1:41 pm
Too few information on what you are trying to do in particular and what is the CCR configuration which fails to do that. Draw a simple sketch with the addresses and netmasks and export the configuration following the hint in my automatic signature.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Users browsing this forum: Google [Bot], Renfrew and 243 guests
