MUM Europe 2020
ashisheitl
Policy to Group
Sat Mar 31, 2007 12:19 pm
Hi all,
I want to configure MT with Four Group.
VIP Group - Open Speed with No Restriction.
Super User Group - Good Speed with No Restriction.
Gerenal Group - Average Speed with Some Access Restriction( Some Sites will be blocked)
User - Fixed Speed with Restriction.
I dont want to put any Authentication for all the group. Every one get access any time without login and get access accrodingly Group Policy.
Please HELP me How to do.
tneumann
Sat Mar 31, 2007 1:36 pm
If you do not want to use any authentification, how do you plan to identify users and (after having identified them) determine to what group they belong?
--Tom
ashisheitl
Sun Apr 01, 2007 5:29 am
--Tom
By their IPs and MAC....What u think
tneumann
Sun Apr 01, 2007 12:35 pm
Do you plan to use the MikroTik router as a hotspot or not? (Hotspot will give you more options to implement your requirements, IMHO).
--Tom
ashisheitl
Mon Apr 02, 2007 5:48 am
--Tom
NO SIR,
I am NOT going to use any authentication method...I am confused how to do it...Please explain me
tneumann
Mon Apr 02, 2007 8:36 am
I understand that you do not want your users to authenticate, but nevertheless you could still use a hotspot or not. So what will it be?
--Tom
savage
Mon Apr 02, 2007 11:23 am
4 NICs, 4 VLANs, 4 IP Ranges, 4 Different Queue types... There's a million ways to do this...
Regards,
Chris
shielder
Mon Apr 02, 2007 12:51 pm
try using addresslist
ashisheitl
Mon Apr 02, 2007 1:30 pm
Ok, If i will use address List, How can i define Diferrent Bandwidth to the perticular Address LIST
ashisheitl
Mon Apr 02, 2007 1:34 pm
Excuse me SIR,
I have seven Diferent network
1st network - some IPS in first Group and some are in second group
Same for other network.
I.E - My first group having IPS from some IPs from all Network.
In that case it will NOT work.
Thanks 4 ur suggestion
cmit
Mon Apr 02, 2007 1:43 pm
But that's one of the benefits of using the address-list feature:
You can group the most different ip addresses/ranges together and refer them with one symbolic name when doing queueing etc. later on.
Best regards,
Christian Meis
shielder
Tue Apr 03, 2007 5:47 am
mangle 1st group of customer ip to 1st address-list to 1 rule using ip/firewall/mangle
mangle 2st group of customer ip to 2nd address-list... and so on
Use queue tree to set bandwidth for the group of people. try it.
ashisheitl
Tue Apr 03, 2007 8:51 am
Thank u very much.
Now i ubderstood how to handle the entire show,
But still confused with the implimentation procedure.
Example Please
ashisheitl
Thu Apr 05, 2007 6:56 am
Dear Shielder,
I have tried with MAngle & Queue tree, But Getting Open Bandwidth after putting Limit=25K & max limit=50k.
Its NOT working, any other idea
Users browsing this forum: erlinden, Google [Bot], Ixam, j4c4k, Sob, zandhaas and 108 guests
