hel
How to get an interface of connected pppoe client using CLI?
Wed May 15, 2019 4:47 pm
I have 20 pppoe servers on mikrotik which set up on different isolated VLANs.
I need to get connected clients by specific vlan interface.
In winbox I have interface read only value in a status tab.
Is it possible to get it/use as filter using CLI?
sindy
Re: How to get an interface of connected pppoe client using CLI?
Wed May 15, 2019 5:07 pm
It is relatively easy to get it:
put ([interface pppoe-server monitor <pppoe-client-name> once as-value]->"interface")
It is a bit resource-consuming to filter on it:
foreach counter=ifc in=[interface pppoe-server find] do={if (([interface pppoe-server monitor $ifc once as-value]->"interface") = "carrier-interface-name" ) do={put [interface pppoe-server get $ifc name]}}
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
hel
Wed May 15, 2019 6:00 pm
Thanks!
Successfully made a csv list using this command:
foreach ifc in=[/interface pppoe-server find] do={put ([/interface pppoe-server get $ifc name].";".[/interface pppoe-server monitor $ifc once as-value]->"interface")}
Users browsing this forum: No registered users and 78 guests
