mischa
Load balancing 2x WAN on same FTTH gateway
Wed May 15, 2019 6:23 pm
I see a lot of topics about load balancing multiple WAN, but has anyone have any experience with load balancing 2 FTTH (fiber to the home) connections from the same IPS and therefore probably on the same gateway?
I know routers from other vendors like Ubiquiti have problems with 2x WAN on the same IPS gateway.
And if one connection is 500/500mbps and the other 200/200mbps will I have a 700/700mbps connection?
Mischa
cdiedrich
Forum Veteran
Forum Veteran
Re: Load balancing 2x WAN on same FTTH gateway
Wed May 15, 2019 6:34 pm
Multi-WAN with same gateway works as described in this thread.
Regarding the resulting bandwidth, you will have 700/700-ish with multiple flows while one flow cannot be greater than the WAN link it is assigned to.
Look at the examples in this manual page.
-Chris
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
Sob
Wed May 15, 2019 7:38 pm
Same gateway address for multiple connections is possible with gateway=<address>%<interface>.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
mischa
Wed May 15, 2019 9:54 pm
Thanks for the quick response.
Mischa
Users browsing this forum: mirk and 7 guests
