Steveocee
How to PCQ this?
Wed May 15, 2019 8:01 pm
I just can't get my head around using PCQ to do what I want. Any help would be appreciated.
This is for my internet connection which is a PPPoE client and I am using an SFQ rule as follows:
/queue simple
add max-limit=55M/16M name=WAN_CONTROL queue=default-sfq/default-sfq target=pppoe-out1
All I want to do is apply a PCQ to that where the router allocates the bandwidth per client. My understanding is that the pcq-rate would =0 for this to happen? Just where and how do I do that?
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
Steveocee
Re: How to PCQ this?
Wed May 15, 2019 8:06 pm
OK, This is working as far as I speedtest from my PC and I can see the queue hitting limits. So it's correct in that it works, but is it correct in it's implementation?
/queue simple
add max-limit=55M/16M name=WAN_PCQ queue=pcq-download-default/pcq-upload-default target=pppoe-out1
CZFan
Wed May 15, 2019 11:50 pm
Target should point to internal subnet, rest looks good
MTCNA, MTCTCE, MTCRE & MTCINE
Steveocee
Thu May 16, 2019 10:53 am
I have 3 internal subnets so would that still work? If rather keep it a simple queue if I can, I know I could mangle & mark but if rather try to keep it simple.
CZFan
Thu May 16, 2019 10:10 pm
Are the subnets consecutive? If so, aggregate / summarize the subnets
sebastia
Fri May 17, 2019 5:13 pm
when defining queues / limits / ... upload is first: queue=<up>/<down>
another option for multiple ranges: use parent queue with the limits defined there
Users browsing this forum: No registered users and 5 guests
