jsmalo
Port Forward in r11e-lte
Wed May 15, 2019 9:03 pm
Hi everyone,
I need help from someone :-)
I try to open a 88 port for CCTV on IP 192.168.1.102 and followed all in Mikrotik manual but still no access.
all my configurations above:
add chain=dstnat dst-address=192.168.1.1 dst-port=88 protocol=tcp action=dst-nat to-addresses=192.168.1.102
mkx
Re: Port Forward in r11e-lte
Thu May 16, 2019 8:50 am
In the rule it should probably be WAN IP of router in dst-address field, not its LAN IP ...
Where are you connecting from, LAN or WAN? If from LAN, then you should implement hair-pin NAT ... in addition to normal NAT or instead of it, depending on how you want to have it.
BR,
Metod
sindy
Thu May 16, 2019 11:55 am
In another words, draw your scenario (a photo of a handmade drawing is sufficient provided that it contains all the details) and export your existing configuration. See hints on anonymisation in my automatic signature.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Users browsing this forum: Google [Bot] and 81 guests
